Hi Fred,
Welcome to the forum! Our first WA branch meeting for the year is in February at UWA. Hope to catch you there!
The image thing is frustrating, and we're steadily working on it. Hopefully it's rectified soon.
Chris
Thanks for the welcome Chris. Just spent some time reading your post on your race bike. Very inspirational stuff. I'll keep an eye out on the details of the meeting and see if I can make it or not.
fffffred wrote: ↑Thu, 10 Jan 2019, 08:39
I've noticed that even though I've registered, my account is quite restricted. I can't search or view pictures attached to post...
Those restrictions should only apply to your very first post. I just tested, and I believe you can attach images now. Just drag suitably sized (not megapixel) images from a file explorer to the edit window, click the mouse cursor where you want it to appear, scroll down and click on "Place inline".
It's all part of the hassle of trying to keep spammers away. Sorry for the inconvenience.
- There are holes in the chassis - usual areas of rust (floor pan etc) + dodgy repairs
- Electrical gremlins - ie no ignition barrel. Cranks over, but doesn't stay running.
- Clutch cyclinder seized
- rubbers need replacing
The upside...
- rolling
- registered
- reasonable price
- it's a wagon... (so hopefully more space for batteries)
- it's a mini
I'm keen to hear from you @brendon_m what I should budget for the conversion... need to run it by the CFO....
My moke cost me about $9000
$4000 for the motor and controller kit (don't know if my motor/design will work in a mini directly as apparently the engine bay is narrower)
$2500 for 2nd hand imiev battery
$1000 for licensing/engineering etc
$1000 for BMS,dcdc,chargers etc (more needs to be spent here for a daily driver)
$500 for other bits and pieces
$0 labour
Then I had about another $1000 in fixing up brakes and body work etc.
If I were to do the moke again I would definitely go that way about it. I think either an imiev/outlander motor or a motor from a Prius wouldn't have been a better way to go. The gearbox is just too noisy and I wish had gotten rid of it.
