Charging your non-Tesla EV from a Tesla charger
lopezjm2001
Real Name: John Lopez
Post by lopezjm2001 »
Is anybody charging their non-Tesla EV (j1772) from a Tesla wall charger using a Tesla Tap or similar adaptor? It works in the USA but does it work in Australia?
[img]http://www.umc-j1772.com/image/cache/ca ... 00x500.JPG[/img]
http://www.umc-j1772.com/index.php?rout ... duct_id=50
I also found the JDaptor Stub but they state "Only for cars sold in North America and Japan!
JDapter Stub does NOT work in Europe, Australia or New Zealand"
Also found this one but not sure it will work in Australia i.e. https://www.evseadapters.com/products/t ... 72-adapter
I am finding it hard to find a level 2 charger 7.6kw outside Sydney using Chargepoint or Plugshare to charge my BMWi3 but there are Tesla chargers everywhere.
2016 BMW i3 94AH
Re: Charging your non-Tesla EV from a Tesla charger
Most type 2 to type 1 adapters will work with the Tesla destination chargers.
dgh853
Real Name: David Hiley
Post by dgh853 »
The answer is a qualified yes with a modified Type 2 to Type 1 adaptor but it's complicated.
Assuming by your Avatar you have a BMW i3 then for most Tesla charging stations you can use a Type 2 to Type 1 adaptor but it must have the Type 2 end shortened otherwise the pins will not connect as a regular Type 2 to Type 1 adaptor is designed to plug into a charging station not into a Type 2 tethered cable.
From memory it needs to be 11mm shorter. There are some commercial type 2 to type 1 adaptors that already have this shortened Type 2 end.
The three phase Tesla charging stations also implement a different communications protocol. This usually works for i3's but Mitsubishi's don't work with it. There is an internal dip switch in the Tesla wall connector that sets it to a legacy mode and it behaves like a standard Type 2 station and should work with all J1772 signalling compliant vehicles in this mode.
A further complication occurs with single phase Tesla charging stations. They actually split the single phase power and apply it across all three live pins in Type 2 plug (to feed Tesla's three onboard chargers). So their 40A single phase wall connector puts ~13.3A down each live connector. Plugging in a BMW i3 and a type 2 to type 1 adaptor it will attempt to draw 30A down just one live wire. This is likely to trigger the Tesla destination charger to stop or worse, damage the single phase station (I've never tested this though).
2019 Tesla Model 3 SR+
2019 Kona Electric Elite
2013 Nissan Leaf
Post by g4qber »
Already discussed here
viewtopic.php?t=4834
2020 Model 3 SR+ - Delivered Fri 17 Jan ‘20 - k kms 60
lopezjm2001
Thanks for the info. I have bought a type 2 to type 1 adapter cable 32A from EVSE Australia. I have cut off 11mm from the face of the type 2 plug using a battery 4 in handheld grinder with a cutting disk whilst the plug was held in a bench vice.
Finished it to make a flat face with a linisher. Used a knife to cut out the plastic edges to form reams.
That brought the end of the pins within 2mm from the face.
I noticed that the type 2 plug has a 220 ohm resistor from PP pin to earth pin. I assume this value tells the charger station that the EVSE is limited to 32A.
Will test it soon and let you guys know if it works.
2016 BMW i3 94AH
lopezjm2001
2016 BMW i3 94AH
lopezjm2001
Found a Tesla charger where my adaptor would not work at Gosford Motor Inn. Just kept getting the message "Mains power too low". Maybe this charger was not set to legacy mode. Did not try it but google says it might have worked if I had locked the car before plugging in. Maybe next time...
https://www.plugshare.com/location/174476
2016 BMW i3 94AH
Post by reecho »
lopezjm2001 wrote: Thu, 27 Dec 2018, 06:51 Found a Tesla charger where my adaptor would not work at Gosford Motor Inn. Just kept getting the message "Mains power too low". Maybe this charger was not set to legacy mode. Did not try it but google says it might have worked if I had locked the car before plugging in. Maybe next time...
It could well be that the mains power is too low....
brunohill
Real Name: Phil
Post by brunohill »
I tried two 3 phase Tesla destination chargers in Milawa Vic with a Tesla to anything (15 amp socket) adapter with the 10 amp (10.6 amp) Nissan supplied EVSE. They would both start OK but would only run for about 15 minutes and then trip out. ??? ??? ???
Perhaps next time I should bring the switchable EVSE and see what happens when set on 6 Amps or 15 Amps.
lopezjm2001
reecho wrote: Thu, 27 Dec 2018, 19:21 It could well be that the mains power is too low....
It does not make any sense. The Tesla destination charger is rated for 32 amps, three phase as marked on the rating plate.
2016 BMW i3 94AH
Post by brendon_m »
May be an actual fault, as in the supply to the charger may only be 350v not 415v or a phase has dropped out or something
lopezjm2001
Maybe but I would have expected the Tesla charger LED to blink if it had a fault.
I tested my adapter cable at Stanhope village shopping centre yesterday and it worked ok. https://www.plugshare.com/location/137108
2016 BMW i3 94AH
lopezjm2001
Today I charged my BMW i3 at Stockland Wetherill Park https://www.plugshare.com/location/130447 using my Type 2 to type 1 plug adapter.
Once again I got the error "Mains power too low". So I tried doing it with the doors locked and it did not work.
Then after some persisting stuffing around I found that it would work if I pressed the type 1 plug button in and keep it pressed in for about 3 seconds during and after plugging into the BMW i3 and it worked and the Tesla charger charged my BMW i3. It seems to be a timing issue of the Tesla communications protocol. See photos.
2016 BMW i3 94AH
Post by reecho »
Ah...The same as the Outlander. Legacy mode time...
lopezjm2001
I just charged up at Rouse Hill Town Centre car park https://www.plugshare.com/location/17075 on a Tesla charger. Worked ok. I have installed a meter to the type 2 to type 1 plug adaptor cable to read the current and power drawn. As shown it was drawing 31.26 amps, 7.3kW at 236.4 volts.
2016 BMW i3 94AH
SlyDog
Real Name: Alfred
Post by SlyDog »
Hi, I was wondering if you've tried the cut-off type2 to type1 on a type 2 charging station?
I live in Perth and we have plenty of type 2 stations now which I use for my Outlander PHEV.
I'm worried that if I cut my connector to use Tesla destination chargers that I might not be able to use the Type 2 stations anymore.
Thanks,
SlyDog
dgh853
Post by dgh853 »
You can trim the type 2 end and still use non-Tesla Type 2 charging stations. The only practical issue is that by trimming the end of the Type 2 adaptor is that it will no longer lock into the charging station (as the lock indent is effectively removed by trimming). That means there is no security on the cable and it could be stolen. A small padlock arrangement at the car end would provide some deterrence.
2013 Nissan Leaf
SlyDog
Real Name: Alfred
Post by SlyDog »
Thanks for the response...I thought this might be the case....bugger. I have a lovely curly 5m Type 2 to Type 1 so can't lose it. I'll have to make do until I can find an affordable cable I'm willing to cut.
Thanks again,
SlyDog
Post by g4qber »
Should/could this topic be moved to “charging infrastructure”
g4qber wrote: Thu, 28 May 2020, 07:35 Should/could this topic be moved to “charging infrastructure”
Done.
Post by g4qber »
Note that the last pic of the HPWC shows that part no. Ends in 02-J
Supposedly 02/03-x units are locked into Tesla’s even with legacy mode enabled.
Interesting how holding the type 1 microswitch down for 3 secs seems to work.
EVdownUnder
Real Name: Patrick Ulrich
Post by EVdownUnder »
Very interesting thread. I have noticed that most (possibly all) newly installed Tesla destination chargers were incompatible with my Kona, when nearly all old ones work fine.
Does anyone know for sure if the new (part number 02-x) ones can be set to "universal"? And if yes, have the switches correct setting for the "universal" mode?
One of the country Victoria motel I visit have their charger set to Tesla only and are willing to let me open it and change the switches, but I would not attempt it without knowing which position the 2 micro-switches need to be set at. Just in case I make it work for my car but fail for the next Tesla customer :?
Pretty sure that shouldn't be possible but don't want to be the one testing the theory.
As of 26 October 2020 (13.5 months of ownership)
40'000km at an average speed of 57km/h
126Wh/km from new
Post by g4qber »
viewtopic.php?t=5227
Link to which dip switch to flip by @reecho
viewtopic.php?t=5971&start=25
@Peter C in Canberra’s volt charges on all Tesla HPWCes he’s visited
lopezjm2001
EVdownUnder wrote: Sat, 06 Jun 2020, 17:53 One of the country Victoria motel I visit have their charger set to Tesla only and are willing to let me open it and change the switches, but I would not attempt it without knowing which position the 2 micro-switches need to be set at.
The photo shows dip-switch 2 in the up position. The installation video tells you to leave dip-switch 2 in the up position.
Set the dip-switch 2 in the down position (off position) and it starts charging right away.
Short cut for Tesla Charger install video:https://www.tesla.com/support/installat ... edirect=no
2016 BMW i3 94AH
Post by g4qber »
TPN ends in 81-J
Maddington Toyota
1910/1914 Albany Hwy Maddington
http://api.plugshare.com/view/location/271270
