In the process of buying a large house block out Ipswich way and with it comes the opportunity to build the house of our dreams (within realistic budgets) and as part of that experience I need to wire the house starting at the street (70m away).
Now the bit I need a hand with... I am not the most electrically minded person on the planet, while I do have a basic understanding of electricity.
I have a nephew who is an electrician who is going to help out at family rates.
My nephew advised me that they no longer run wires from pole to pole like they used to, so the plan is to have a pole about 12m from the road (where the main meters will be for reading) and run all wiring underground from there to a sub box at the house.
The puzzle to be solved... I want it all, and I want it as cheap as possible.
Yes I understand that it won't be cheap, but there are ways that are less wasteful than others to achieve the same result.
I want 3 phase on the property (no problems nephew said it's easy done).
I want a big solar system (probably around 7kW)
I want super clean power for my home theatre room (been obsessed with sound for about 40 years)
One day when I finish my trike I want to be able to charge it at a decent rate.
Since I don't know the small details of how everything works I have been struggling to get my head around how to achieve this.
I am thinking bring the 3 phase down to the sub box, where each phase will have it's own filter, hook the solar up to one of the phases (3 phase solar is crazy dear) perhaps store some of the electricity in batteries to be consumed by the home theatre room only. Run the house off the solar and send back what is left over.
Diagrams, ideas, thoughts please.
I want it all...
- EV2Go
- Real Name: Paul
I want it all...
- Adverse Effects
- Real Name: Adverse Effects
I want it all...
and dont forget the ethernet network in the house and shed
- EV2Go
- Real Name: Paul
I want it all...
Most definitely.
Because most of the services are still out on the road I am going to need to bring power, water, NBN in from the road, and return data, switches for electric gate, and security cameras.
Always wanted one of those fancy gates that someone presses the button on the driveway and you let them in.
Heck I could get real fancy and do face recognition entry
Don't think I will bother bringing gas down from the street as it will probably work out cheaper to use big bottles.
I digress back on topic...
I want it all...
The Qld electricity distributor will require multi-phase solar if you go larger than 5kW. Your 70m of ug cable will need to be sized to minimise voltage drop under full load, and minimise voltage rise under solar export (assuming you don't self-consume or store in batteries - including an EV). Refer your nephew to table C7 at the back of AS/NZS3000: Wiring Rules. The future is "all electric" - not gas - in my personal opinion.
MrD-85-TSLA
- EV2Go
- Real Name: Paul
I want it all...
The gas if for cooking only everything else is going to be electric since I can make that myself.
Can you run 2 x 5kW systems on two different phases?
If I can make enough power I would really like to have a walk in cool room for summer.
- Richo
I want it all...
I didn't think 3-phase PV was that expensive.
I had been looking at 15kW 3-phase for commercial properties.
Most of the suppliers try to put you on a 5-year loan plan.
The offset from the reduced power bill pays for the loan in the 5 years.
Although not as cheap as buying outright with no loan.
I guess an ESS and no company supplied mains is out of the question?
30-60kWh...
Then you could DC fast charge 100kW+
30-60kWh...
- EV2Go
- Real Name: Paul
I want it all...
What prices have you been given Richo for 15kW 3 phase? The only prices I have seen were at a home show at may not be the cheapest, but they were talking circa 30k for 7kW.
- Real Name: Rusdy
I want it all...
EV2Go wrote: The gas if for cooking only everything else is going to be electric since I can make that myself.
Pffft... why gas for cooking? Why not direct feed from DC bus (if you have high voltage DC bus). This guy did what I've wanted to do since yonks ago, he even went further by direct feed from solar panel (that's right, NO battery!!)
Obviously, you need induction cooker (heating element is just too inefficient):
https://www.youtube.com/watch?v=jPtBYg6N29E
I'm surprised why no one in Africa (for example) hasn't done this yet. Loads of entrepreneur made money by simply selling small solar panel to charge mobile phone batteries and small lighting. This one is even more bada$$ (and much more useful to solve .respiratory disease from cooking
- Richo
I want it all...
EV2Go wrote: What prices have you been given for 15kW 3 phase?
$20k for 15kW
$11k for 8kW
That was using SMA tripower inverters, fully installed.
- EV2Go
- Real Name: Paul
I want it all...
That's one serious inverter
