Carbon capture and storage - Worthy tech or BS?
https://www.businessnews.com.au/article ... -288654053
Hardly a surprise that our Industry Minister is endorsing this technology ahead of alternative low-carbon energy systems, but what do you think?
Is carbon dioxide capture and storage underground a worthwhile endeavour or is it just plain hope that it will distract us for long enough to keep burning fossil fuels?
Personally I put it in the same category as fuel cells. A technology that works, but not practical on the scale needed to put a dent in the world's CO2 emissions.
Apologies if you can't read the article - online papers are trying to make a buck wherever they can.
Post by rhills »
It is my belief that more money is being funnelled into this kind of thing than into Alternative Energy solutions, but I don't have hard evidence for that.
If it's true however, I'd have thought that limited public money was better spent on ramping up technologies that are proven ("unsightly" wind, wave, big solar) rather than trying to prove unproven concepts.
But that might result in less Petroleum Industry finance to help one get elected and that would never do, would it?
Total Petrol: 692.1L
ODO: 57409
Av Consumption: 1.21 L/100km
jonescg wrote:Is carbon dioxide capture and storage underground a worthwhile endeavour or is it just plain hope that it will distract us for long enough to keep burning fossil fuels?
There's no need to spend any more money "researching" Carbon Capture and Storage. They've implemented it on a Canadian power station. So it should now be compulsory for all coal-fired power stations to implement it or stop burning coal. Image
The only reason it might be economically viable for that Canadian power station is that they are selling the liquid CO2 to oil companies for "enhanced oil recovery". This is where they pump the liquid CO2 into otherwise spent oil wells as a solvent, to flush out more oil that, when burnt, releases 3 times as much CO2 into the atmosphere as the CO2 that is sequestered when they finally stop flushing and cap the well.
This, of course, is a crime against humanity, and should be illegal.
bladecar
Post by bladecar »
I fail to see the "tech" in carbon capture and fail-to-store.
You clean your house by hiding the dirt under the carpets, the furniture, the beds.
Later, where is the dirt. Same place. Where's the tech there?
There's a monster amount of co2 coming out of each coal-fired plant each day.
Where are they technically going to hide it? And under pressure?
Things under pressure are always trying to escape.
What occupies where it's trapped (not stored). Water, or spaces for the pressure to 'relieve' itself.
How long must it be trapped under ground under pressure, always determined to escape, to get out of there, to go where? ? ?
It's the same as getting into debt. You smile and smile and smile and....
Sure, introduce carbon capture and storage. Start by shutting down all the coal and oil-powered power plants and then fit the hardware, one by one, as you re-start each plant. PROBLEM SOLVED. I predict we would see no more than 4 plants ever restart before the coal hit the fan.
You look at the size of the hole of some established coal mines. There were solids taken out of there. Now, imagine the volume of the GAS that that hole would have transformed into. Now, shove it back under there :):):)
They say that solar panels are a problem because it is a consumer-led change. They say that solar panels have made coal and oil-powered (and atomic, if you make 'em pay for build and bust) electricity more expensive. We must apply solar (or any tech truly shown to equal or better it) consistently and persistently to make the dinosaur power truly untenable, but only because it's part of our only planet's survival.
We don't want no adverse effects from co2 no more.
Edit:ed because I never run out of good ideas.
Edit: I edited it.
2nd Edit: I technically edited the punctuation.
Shirker
Real Name: Matt Smith
Post by Shirker »
CCS is absolute genius - at least the version that's been in production for millenia:
bladecar
Post by bladecar »
...and to this human, they are beautiful too.
The birds love them (and need them).
The Koalas love them (and need them).
And trees are because they are, not because we can make them so.
So we must leave them alone as much as we should.
Shirker wrote: CCS is absolute genius - at least the version that's been in production for millenia.
The trouble with that version is that it's way too slow to save us from our coal burning. We've burned the results of about 60 million years of that solar-powered carbon sequestration, in 200 years.
The other version is complete BS.
Rusdy
Real Name: Rusdy
Post by Rusdy »
Technologically, yes. Financially, BS.
When it comes to energy production, LCOE and EROI are the 2 main variables you need to look for.
CCS increases the price of 'cheap' coal, and loses its competitiveness compared to other renewables. To quote:
"Technologies like hydro, nuclear and geothermal generation also have high rates of capacity utilisation and therefore may also provide better value for money in terms of costs per megawatt-hours (MWh) generated and per tonne of CO2 avoided."
Source: Click Here
Now, there are lots of fights regarding the 'competitiveness' due to baseload power VS renewable intermittent power. It's not a simple explanation unfortunately, as it is a 'yes' and 'no' at the same time. So, for those who interested in reading more, I tried to explain it as plain as possible here: Click Here
----Edited---------
Just found this for NSW pricing estimate:
Source: Click Here
Really, someone is desperate to keep coal going.
