I had a salesman from Diamond Cell Solar
http://www.diamondcell.com.au/PRODUCTS.6.0.html come out yesterday
I was expecting a site surveyor to come out to make sure, amongst other things, my shed was strong enough to hold 150kg worth of solar panels on its NNW facing roof.
I picked these guys as their website showed panels that had a max power point voltage of 45V, which 2kw worth meant a DC bus voltage at max power point of 360V (the peak efficiency point of grid inverters on 240vac)
What I actually got was a salesman whose product knowledge was next to nothing (kept referring to kwh as k/w and the inverter was a motor apparently)
Then had the audacity to suggest his product was so good that I wouldn't need to get other quotes, just sign here for a 2kw system for $10k after rebates (except he described it as a 16k/w per day)
yep - every boom brings out the charlatens
Somewhere I have a calculator that works out average yearly output for an array. I'll dig it up and post a link
