Code Help
EV2Go
Code Help
Post by EV2Go »
Had a minor glitch when trying to rename one of the forms... VB in it's infinite wisdom wiped out all the code and controls off the form.
Thankfully I left myself a few formula clues in the previous post. Will have a lot of rebuilding to do, but at least I have some code to work from.
7circle
Real Name: Ken
Code Help
Post by 7circle »
Yow, that must of hurtImage, lossing code you built up.
You will hopefully will find recreate a better more efficient code Image structure. And remember to back up ... for a while. Image
Code Help
Post by rhills »
The lesson to take home here is never, ever write any code without using version control. There are excellent open source options around so good version control doesn't cost you anything. Whenever I start any software project, whether something simple for home or a professional project, the first thing I do is create a repository for the code. I couldn't begin to quantify the time that's saved me.
If you don't know where to start, take a look at either:
Subversion + TortoiseSVN (http://subversion.apache.org/ and http://tortoisesvn.tigris.org/) - These are very mature products with pretty good documentation.
GIT + TortoiseGIT (http://git-scm.com/ and http://code.google.com/p/tortoisegit/) - These are newer so a little less mature, but represent the "way of the future".
If you've never had much to do with Version Control systems before, this may seem complicated and difficult to learn and an unnecessary distraction from the task at hand (ie cutting the code) but believe me, however many hours you invest now in learning how to use a version control system, it will repay you many times over the next year or two.
Total Petrol: 756.3L
ODO: 67508
Av Consumption: 1.12 L/100km
EV2Go
Code Help
Post by EV2Go »
I am my own worse enemy when it comes to version control. I generally make a zillion copies and then forget which is the latest.
I have in the past had access to things like VSS and TFS but it is my own slackness that has prevented their use.
I figure the most simple way is to have a project folder for each project and within that folder have about three working copies, each folder has the date on it.
Every time I want to save a copy just overwrite the oldest one. It is generally when I do a major code change that things like this happen.
Code Help
Post by rhills »
I was like that a few years ago. When I took the plunge with Subversion, after about 3 months, I wondered why I'd ever contemplated living without it. I've since changed over to GIT but I use that for everything, code, documents etc. etc.
I also used to try and manage things manually, and like you, every now and then would stuff up monumentally.
You don't need separate servers and offline storage to use either Subversion or GIT, you can just use the computer you're developing on. Of course, if you have a separate computer, then you get backup for free so that's an even better way to go.
Seriously, it's really worth the effort to install and learn either Subversion or GIT. DO IT NOW!
I'm happy to provide some guidance via PM if you want to take the plunge and get stuck.
ODO: 67508
Squiggles
Real Name: Neil
Code Help
Post by Squiggles »
I'll second the nomination for subversion. It can be used for all your files. Also good for projects with multiple contributors.
I have it running on my Linux server and colleagues have access to it via the internet....damned good thing!
