On Monday my EV moved for the first time, and since then I have taken it for a few test drives around the block. I still can't quite believe that it backed out of the garage under it's own power! Rather than the EV grin I have the "EV stunned disbelief" look
Some amusing bugs were (i) it ran backwards for a while as I had the motor wiring wrong and (ii) it made a hell of a noise until I realised wheels work better with wheel nuts tightened!
For pictures and info I have a draft evalbum entry.
On Thursday my local mechanic will give it the once over to make sure there are no little details I have missed (and check for minor defectable items). Before I started this project I was pretty green on the mechanical side so I want him to check that I put everything back together OK.
I have checked the height requirements and I am just 10mm too low at the back despite the extra 190kg (7 Optima D31's) in the boot. Looks kinda mean that low, actually
Still lots of little things to work on, will have a go at Regency in a few weeks.
David
