200mph what to use AC or DC??
Where hooligans go to get AMPED
7circle
Real Name: Ken
Post by 7circle »
I think its got to do with momemntum of the air fluid and the impact and reflection with the surface and laminar air flow.    Image Thats as much word dropping that I can think at the moment.
The shape of the rider will of course have a huge impact. Broader shoulders and hips and maybe shoe size.
But at over 200km/h the spread of air with a fat nose cone /wheel maybe a big problem. A pointy nose is a problem at over 100km/h when cornering.
I guess if the bike is for track/road too its a compromise. Just get as much torque to the road/salt as possible.
EV2Go
Post by EV2Go »
I don't know the fancy names but that about sums it up Image
While my bike has the more modern look, I have wondered a few times if it is as aerodynamic as some of the older looking bikes.
With having shaper angles I wonder if the air exiting the outer edge of the fairing has more to battle with.
If the angle the air comes off the fairing is greater than a smooth rounded curve, then it meets the air running along side the bike with bigger turbulance, whereas the more rounded front is guiding the air down the bike.
But then the flip side of that if the air on mine gets away from the bike better then it is less likely to create drag on the rider.
Maybe those round noses work better when the sides are pannel in to stop the air grabing the rider???
EV2Go
Post by EV2Go »
I was just walking out the door when I noticed this...
Can only assume that Kawasaki was trying to get the air away from the bike.
Also noticed they are trying to take the air over the top of the bike rather than to the side.
Catavolt
Real Name: Jon Eggenhuizen
Post by Catavolt »
At what speed does the bike direct air around you?
EV2Go
Post by EV2Go »
Bit wet outside to do a test ride, but it seems to direct air around me from fairly low speeds through to over 200kph. I have noticed at about 245kph (at the end of the drag strip) the back of my jeans flap a bit that isn't there at ~200, but I think that is more to do with the fairing that covers the engine, then the top bit, also the air from the radiator exits in front of the leg.
While I am semi tucked it (fat bugger can't get fully behind screen) I don't notice any major buffeting it is only when I sit up at the end of the strip that it starts to act like a parachute.
Catavolt
Post by Catavolt »
I was planning to use 4 x Double stack brushless Mars motors run at 144v from 2 x 600amp Kelly controllers, after reading through the rules of DLRA We can only use two motors max.
What a pain.
I have two 144v Kelly 600amp controllers on order for the TTXGP to use with the Enertrac Hub motors, so it would be good to utilise them for Catavolt's land speed run.
Anyone know of a brushless dc motor with around 75kw 144v?
EV2Go
Post by EV2Go »
Could you use a 1k or 2k Zilla in series or parallel to save controller space?
the zilla is a DC motor, where as brushless DC is more a bastardised AC.
EV2Go
Post by EV2Go »
Ahhh I checked to see if the Mars were all DC first before I posted, I didn't realise they were brushless and required a different controller.
Catavolt
Post by Catavolt »
The bike has been passed to use 4 motors so we are back on track.
I found this Channel 7 interview of the Catavolt bike last night.
http://www.youtube.com/watch?v=73Uw8agi98w
Post by Adverse Effects »
you guys are missing 1 vital thing in the way of aerodynamics
you may only to be able to do so much to the bike in that area
so why not make the rider fit the holes on the ferings?
like this and make the rider turn it in to a streemliner Image Image
granted you will look like a wanker walking around in the suite but it will make you go faster
[EDIT] are you allowed to have a push car to get you up to say 100Kmp/H ?
Last edited by Adverse Effects on Mon, 14 Feb 2011, 17:12, edited 1 time in total.
Catavolt
Post by Catavolt »
Adverse Effects wrote: you guys are missing 1 vital thing in the way of aerodynamics
I would like to keep the bike looking as much like a normal road bike as possible with a normal Rider or it doesnt count for me.
Here is a recent article on the bike.
ok so you ether are a female or you dont realy care about winning
why do i say that?
i have never seen a bloke say "i know that makes us go 15Kmp/h faster but it dont look preity so we wont do it" that is the domain of females choosing looks over function
Adverse Effects wrote:i have never seen a bloke say "i know that makes us go 15Kmp/h faster but it dont look preity so we wont do it" that is the domain of females choosing looks over function
How about using some upper case letters at the start of sentences while you are insulting half the world's population.
i dO aPoLiGeS
i am dislexic and have been all my life
i was 20 before i could even read and write and i am sorry that i have not exiled in the written word
if it where not for google and spell checker you would not be able to read most of what i say
as for
first go back to school females are not 50% of the world's population
second i dont see it as a insult saying 1 sex is much better at seeing beauty and the other sex is better at seeing function
Catavolt
Post by Catavolt »
Catavolt is please to announce the True Solar Time has become a Major sponsor!
True Solar Time and NHP will be providing a Green power source for Catavolt at Speed Week.
Here is a little bit of what they do:
True Solar Time specialises in the installation of solar powered technology.
It is a division of Spiden Electrical Services Pty Ltd which is a full service electrical contracting business.
Spiden Electrical is now celebrating 20 years of business and is involved in http://www.nhp.com.au/
electrical projects for large commercial and industrial work, including office buildings and
major retail stores being constructed and renovated throughout Melbourne, Victoria and other States of Australia.
From its first day of operation, Spiden Electrical has been growing and changing to keep
pace with new technology, the use of sustainable resources and the design, supply and installation
of solar powered systems. Due to the demand of customers for a reduction of greenhouse
emissions and sustainable energy, the division of True Solar Time was founded.
True Solar Time now designs and installs energy management systems that utilise alternative
power supplies, for example: standalone power supplies, battery backup, solar, wind and
generator technology. This division operates in conjunction with Spiden Electrical which provides
a service for the installation of electrical power, lighting, voice, data and other related systems
in new and existing buildings. This ensures all your electrical and power supplies are catered for.
The team at True Solar Time is committed to reducing their client’s greenhouse emissions and
has an overall goal to achieve the best for a customer. Their extra effort and desire for a new
challenge and accreditation by the Clean Energy Council, results in the business of True Solar Time
attaining a high standard when completing projects.
At Spiden Electrical Services Pty Ltd and True Solar Time, we continue to enjoy the loyalty
and fellowship of the many customers we have had over the years. We appreciate these relationships
and strive to continue to provide exceptional service through consistent quality and constant professionalism.
Please contact [url=http://www.truesolartime.com.au%20]http://www.truesolartime.com.au [/url]for further information.
EV2Go
Post by EV2Go »
And now a word from our sponsor Image
Congrats on the new sponsorship.
Catavolt
Post by Catavolt »
Here is an article out of The Australian Motorcycle News Mag
Catavolt
Post by Catavolt »
Here is an updated picture of Catavolt 2011 almost ready.
Speedily
Real Name: Anthony
Post by Speedily »
looking good Jon
Catavolt
Post by Catavolt »
I have some competition:) oh no not the Spog
http://www.ibys.org/shed/?p=394
EV2Go
Post by EV2Go »
And when he has kids they will be the Sprog of the Spog...
Catavolt
Post by Catavolt »
ewwwwh yuck
Nice build though should be interesting.
EV2Go
Post by EV2Go »
Looks like one of the bigger CC Honda frames to me (orange wheels are a bit of a clue).
gmacd33
Real Name: Greg MacDonald
Post by gmacd33 »
Hey Spog folks!
Why are you using a separate motor to accelerate from standing? Those DC motors have max torque from 0rpm, so would be best to accelerate I would have thought?!?
Greg MacDonald
Chief Technical Officer
Lithium Battery Systems
