[URL] changes to <a href>
Hi Andrew
Try entering
[URL=http://insideevs.com/bmw-i3-to-rex-or-not-to-rex/]
Etc
Into a post
Editing the post changes it to <a href>
also weird conversion occurs with images.
[IMG]uploads/1608/Screen_Shot_2014-05-04_at_7.52.37_am.jpg - I've dropped off the end tag.
<img src="uploads/1608/Screen_Shot_2014-05-04_at_7.52.37_am.jpg" />
2020 Model 3 SR+ - Delivered Fri 17 Jan ‘20 - k kms 41
I'm having the same problem. How come there has been no response to this problem when it's been over two weeks since g4ber posted about it?
If you edit a post _all_ URLs and IMGs get completely broken and it takes a lot of work to fix them. This never used to happen. It gets so I just leave my errors now because I'm too scared to edit my posts.
Still not fixed
I'm thinking of linking to the ozleaf proboards in future until it is fixed
+1
The forum is tedious enough to work with before. This just makes it even more painful.
perhaps just post to myimiev.com and quote it here until it is fixed.
Andrew
Real Name: Andrew Brown
Post by Andrew »
It seems like this may be a bug with the most recent update of the forum software. Apparently it will be addressed in the next release (hopefully soon!)
http://forums.webwiz.co.uk/what-causes- ... 31026.html
7circle
Real Name: Ken
Post by 7circle »
ooooohhhhh
Above link to there forum has : Posted: 11 June 2014 at 11:16am
"It appears to be an issue with the function that converts HTML in to BBCode.
Will have this fixed for the next release."
And the new release is out ...
Web Wiz Forums Downloads
The latest version:
Web Wiz Forums 11.01
Released 10th September 2014 [Release Notes]
Download Web Wiz Forums and other related Web Wiz Forums tools.
Release notes look useful for 11.0 on 2 Sept 2014
7. new_post.asp - removed tabs from subject that can break URL Rewriting
8. edit_post.asp - same as above
9. pm_new_message.asp - same as above
10. functions/functions_edit_post.asp - fixed bug that would not convert HTML images and URL's in to BBCode
20. edit_post.asp - same as above
Image [:wistle] [:;]
Andrew
Post by Andrew »
We have now upgraded to Version 11 of the forums software! Let's see if this update resolves many of the recent issues that have occurred.
well lets try it
http://youtu.be/_zhzlEoaH_4
[EDIT] 10 sec later
[EDIT 2] looks like that is fixed
Last edited by Adverse Effects on Wed, 01 Oct 2014, 18:11, edited 1 time in total.
Adverse Effects wrote: looks like that is fixed
Yes, indeed! I just edited one of my most image laden posts:
viewtopic.php?t=980&p=36932#p36932 . (The changes are to do with BMUsend, now called CMUsend). It would have been unthinkable before this fix.
Thanks, Andrew!
yes thank you
Great Image
7circle
Real Name: Ken
Post by 7circle »
Yeahy... Looks fixed. Thanks for update Andrew.
But clivk-bait VIGLINK embedded url links seem to be appearing like weeds.
See release notes :https://www.webwiz.co.uk/web-wiz-forums ... -notes.htm
Version 10 beta 1 (13th May 2011)
"265. admin_ads_settings.asp - new file for adding Ad Code including VigLink"
So the upgrade may have re-enabled these sneaky thistles.
Version 11.01 (10th September 2014)
1. includes/version_inc.asp - updated version number
2. setup_db.asp - added additional security
3. admin_skin_configure.asp - updated skin options
4. includes/setup_options_inc.asp - added new setup options
5. includes/global_variables_inc.asp - updated to support new setup options
6. includes/quick_reply_form_inc.asp - fixed badly formatted HTML
7. admin_ads_settings.asp - updated to add option to disable VigLink
8. forum_posts.asp - updated to allow disabling of VigLink Ads
9. pm_message.asp - updated to allow disabling of VigLink Ads
But they 11.01 appears to have admin tools to disable these weed click baits.
Hopefully it is simple check box to disable.
Maybe this issue needs a new thread.
7c
