uploading pic as avatar
Admin Requests, General Enquiries and Forum Issues
71monaro
Real Name: Warren
Post by 71monaro »
Can anyone confirm what this message is I am getting when i upload a pic to use as an avatar.
Server Error in Forum Application
An error has occurred while uploading file/image.
Please check the Persits AspUpload Component is installed on the server.
Please contact the forum administrator.
Support Error Code:- err_Access_create_AspUpload_object
File Name:- functions_upload.asp
Error details:-
Server object
006~ASP 0177~Server.CreateObject Failed~800401f3
rgds Warren
MX5 with Prius AC motor and SemiKron inverter
Andrew
Real Name: Andrew Brown
Post by Andrew »
Funny you should mention that - I've just fixed the problem (had to install a component to the forums). This also means you can upload pictures to these forums as well as avatars! Image
EDIT: To upload images and files you must have at least 30 posts or be a confirmed payed-up member of AEVA (edit2: this rule doesn't apply for avatars).
71monaro
Real Name: Warren
Post by 71monaro »
Thank you, It is working now, and the membership cheque is in the mail (well almost, ready to post anyway) Hopefully we get SA up and running soon.
Post by woody »
I noticed you expanded the avatars to 128x128 :-)
Post by acmotor »
Only so he could show off the mags on the magna !
Yeah I'll have to get fatter wheels now to fill it out Image
Andrew
Post by Andrew »
woody wrote: I noticed you expanded the avatars to 128x128 :-)
Yep! It's great isn't it. Some people with custom avatars will need to find a bigger image if it's less than 128x128. For those people using stock avatar pictures it will look slightly blury (but that's what you get for using stock Image )
I hope everyone likes the new size Image
bga
Real Name: Bruce Armstrong
Post by bga »
**GIANT** Avatar files.
Please fix mattW's enormous avatar file:
128 x 128 pixels = 754,197 bytes Image
It's 368 bits per pixel, which must be record.
