uploading pic as avatar
71monaro
Real Name: Warren
Post by 71monaro »
Can anyone confirm what this message is I am getting when i upload a pic to use as an avatar.
Server Error in Forum Application
An error has occurred while uploading file/image.
Please check the Persits AspUpload Component is installed on the server.
Please contact the forum administrator.
Support Error Code:- err_Access_create_AspUpload_object
File Name:- functions_upload.asp
Error details:-
Server object
006~ASP 0177~Server.CreateObject Failed~800401f3
rgds Warren
MX5 with Prius AC motor and SemiKron inverter
Andrew
Real Name: Andrew Brown
Post by Andrew »
Funny you should mention that - I've just fixed the problem (had to install a component to the forums). This also means you can upload pictures to these forums as well as avatars! Image
EDIT: To upload images and files you must have at least 30 posts or be a confirmed payed-up member of AEVA (edit2: this rule doesn't apply for avatars).
71monaro
Real Name: Warren
Post by 71monaro »
Thank you, It is working now, and the membership cheque is in the mail (well almost, ready to post anyway) Hopefully we get SA up and running soon.
I noticed you expanded the avatars to 128x128 :-)
Only so he could show off the mags on the magna !
Yeah I'll have to get fatter wheels now to fill it out Image
Andrew
Post by Andrew »
woody wrote: I noticed you expanded the avatars to 128x128 :-)
Yep! It's great isn't it. Some people with custom avatars will need to find a bigger image if it's less than 128x128. For those people using stock avatar pictures it will look slightly blury (but that's what you get for using stock Image )
I hope everyone likes the new size Image
bga
Real Name: Bruce Armstrong
Post by bga »
**GIANT** Avatar files.
Please fix mattW's enormous avatar file:
128 x 128 pixels = 754,197 bytes Image
It's 368 bits per pixel, which must be record.
