I have tried to use the forum search over the past 2 days and keep getting the following error message:
Server Error in Forum Application
An error has occurred while executing SQL query on database.
Please contact the forum administrator.
Support Error Code:- err_Access_get_search_results_data
File Name:- search_process.asp
Error details:-
Microsoft JET Database Engine
The Microsoft Jet database engine stopped the process because you and another user are attempting to change the same data at the same time.
Any chance of a fix? I find it hard to believe the forum search is being used by another user at exactly the same time every time I try to search. Then again, this is a popular forum!
Search error
- Real Name: Andrew Brown
Search error
Hi sellis, I just did a compact and repair of the Forums database and the search feature works again. This is the first repair it has needed since the forums were created over 2 years ago.
Thanks for pointing out the issue.
cheers,
Andrew
cheers,
Andrew
2013 Nissan Leaf AZE0 with 63 kWh battery upgrade
