> a gearbox will solve torque issues, but not power issues.
> its all about the ratios.
Isn't that what a gearbox does? Sort out your ratios, rather than having a single gear that compromises on your final ratio.
If I want a quick 0-100 time the ratio is going to be different to the one I want for cruising at 110km/h. To keep an electric motor in its efficiency zone, you'll want to vary the motor speed. If you want an underpowered motor to stay within it's power curve, you'll need to vary the motor speed (downwards, espcially with DC motors)
The work around is to massively overspec your motor and to pick a final ratio that works for high speed & accelleration. My calculations put the motor spec at 570.1467 Nm for a 0-100 time of 5s (about what it does now) and 6514 motor rpm to attain 210km/h with the std final ratio in the s15.
Going an AT diff and a lower top speed would enable me to reduce the specs for the motor needed...
> the reason white zombie and the like have such good 0-100kmh numbers
> is because they are still getting full power at 100kmh.
I thought it was because they effectively gear the motor for max torque (the twins are wired in parallel) for launch and then switch it for max power at higher speeds (series) - there's a vodeo floating around on youtube where they explain it... You can do similar things with AC motors, with star and delta setups.
> Its only above 100kmh, that a gearbox would improve power output.
> the type of gear box you would want for that situation is one that
> decreases the total ratio, ie, slows the motor down.
> every automotive gearbox ive ever seen increases the total ratio.
Funny, my gearbox on my 200SX runs 3.692 in 5th gear (1:1) and 2.831764 in 6th gear (0.767:1) - in fact I'd wager that's what most gearboxes do...
sorry...
To illustrate, in 6th gear, at 180km/h the motor spins at 4282rpm (rather than 5583rpm).
I havn't looked into batteries yet, as it's all academic without a drive system, and you don't know what sort of current drain you'll need to support until you've designed everything else.
I'm hoping LiSu cells come onto the market soon, reducing the price of the LiFe packs.
I hear the Telsa roadster makes use of literally a-ton of reconfigured laptop batteries
MikeG
