Page 4 of 21
Posted: Sun, 18 Nov 2018, 21:17
Posted: Mon, 19 Nov 2018, 04:58
by francisco.shi
How much does the brick weigh and how many kwh do you have per brick?
Posted: Mon, 19 Nov 2018, 06:31
The two row module weighs 18.6 kg and stores 3.2 kWh as a complete unit. So each brick of cells like the one above is about 9 kg.
Posted: Mon, 19 Nov 2018, 16:53
by tidalev
4Springs wrote: ↑Fri, 16 Nov 2018, 17:43
I used an off-the-shelf controller for this, mine uses a 0-5V signal (from memory) to control the speed based on the temperature of the coolant.
Do you have any more info on this? I'm looking at a similar setup
Posted: Mon, 19 Nov 2018, 18:51
by 4Springs
Controller info in this post.
viewtopic.php?f=18&t=5249#p64990
There are simpler controllers around if you just run the thing flat out.
Posted: Wed, 28 Nov 2018, 10:11
Not exactly a gigafactory, maybe a kilofactory?
- 3 modules worth.jpg (179.38 KiB) Viewed 2177 times
Posted: Mon, 03 Dec 2018, 21:35
Managed to get a little help from Mike to bring the hoist up the hill. The Hyab truck they use to deliver and install wouldn't fit through the carport, so we had to unload it and roll it down to the shed. While we could have driven all the way back, we then wouldn't have a means to get it off the truck...
We can solve these minor issues
- Hoist arrives.jpg (136.95 KiB) Viewed 2107 times
Posted: Tue, 04 Dec 2018, 12:20
I'm lost - what's that for
Posted: Tue, 04 Dec 2018, 12:29
Richo wrote: ↑Tue, 04 Dec 2018, 12:20
Looks to me like Chris is going to lower the car onto the battery pack
It's awfully big
Posted: Tue, 04 Dec 2018, 12:33
It's a car hoist. It will be installed in the workshop ahead of the Prelude conversion. Since the battery is going where the fuel tank used to be, the hoist will make the whole job a lot easier.
It's a clear-floor type, so they are taller than the regular 2-post hoists.
Posted: Wed, 05 Dec 2018, 12:33
by francisco.shi
Have you done any measurements on the cooling system for the battery pack?
Posted: Wed, 05 Dec 2018, 13:52
I've not yet set the modules up for testing, but I will have several tests to do by the weekend. The one module have already built is to be the 'spare' module, and it's just as well because the thermal epoxy doesn't have the sort of coverage I'd like it to have. It's probably 90 % as good as it needs to be.
However I found some Tesla pack data:
- Tesla pack water temp graph.JPG (77.87 KiB) Viewed 2047 times
So this is a 1.2 C discharge on a Tesla Model S module. The measured internal resistance is about 100 mOhm per cell (remembering there are 74 in parallel and 6 of these in series - so the overall internal impedance of the pack is 0.0081 Ohm. At 297 amps it was generating 715 W of heat - for the first 30 seconds anyway. It dropped off as the voltage dropped.
The heat generation is plotted, as is the delta T in the coolant. From the delta T in the coolant we can infer the heat absorbed by the coolant.
- Tesla pack water heat flux.JPG (70.94 KiB) Viewed 2047 times
It's rough, but should give some idea. Hope to have my data soon.
Posted: Wed, 05 Dec 2018, 16:10
by francisco.shi
Where did you get the data from. I would like to read a bit more about what other tests they did.
Posted: Thu, 06 Dec 2018, 09:26
I should add this was based on a measured DC IR of 100 mOhms per cell, which is probably higher than it really is. But not a lot higher. It's a used pack, so the DCIR has no doubt increased from new (which is supposed to be 60 mOhm).
Posted: Thu, 06 Dec 2018, 09:29
Potted my first complete battery pack with thermal epoxy. Next step is to wire up the BMS and test it
- Potted pack.jpg (134.71 KiB) Viewed 2008 times
Posted: Fri, 07 Dec 2018, 09:09
And then there were two.
- 2nd module done.jpg (141.05 KiB) Viewed 1985 times
Posted: Fri, 07 Dec 2018, 17:41
by mikedufty
Is that a zero motorcycle in the background?
Posted: Fri, 07 Dec 2018, 18:10
Yes, Daniel Klemm's bike. Still has problems and we're trying to re-flash the firmware to make it go. Currently a 50 km/h limited bike with 5 km range and won't take a charge...
Posted: Fri, 07 Dec 2018, 22:06
by mikedufty
Bummer
Posted: Sat, 08 Dec 2018, 21:02
I seem to have about a one-a-day sort of productivity right now.
- Prelude modules.jpg (290.06 KiB) Viewed 1928 times
And now there are four (and a spare).
- 4 done and a spare.jpg (220.67 KiB) Viewed 1881 times
Posted: Sun, 09 Dec 2018, 00:30
by rhills
Well, they look pretty professional IMHO.
How do you think those screws into perspex will hold up against vibration?
Posted: Sun, 09 Dec 2018, 06:55
It's polycarbonate which is tougher than perspex. The screws are also glued in place by virtue of the seal it goes through. I reckon they will be okay.
Posted: Sun, 09 Dec 2018, 08:34
by francisco.shi
Is the potting compound only on the bottom of the cells?
Posted: Sun, 09 Dec 2018, 11:02
francisco.shi wrote: ↑Sun, 09 Dec 2018, 08:34
Correct. The bottom face of the cell stack represents about 20% of the total surface area, and it's all in the plane of the electrodes, so thermal conductivity is at it's highest.
Screenshot from a video I'm preparing:
- potting screenshot.JPG (129.06 KiB) Viewed 1875 times
Posted: Wed, 12 Dec 2018, 20:24
Almost ready to start work
- Hoist installed.jpg (228.25 KiB) Viewed 1841 times
