Page 1 of 1
MX5 Conversion kit up for grabs
Posted: Mon, 03 Apr 2017, 22:58
by woopwoop
Well after many years of lurking and learning so much, it's time to post. Unfortunately, I wish it could be a happier post.
A little while ago I started a conversion on an MX5, but I've just found out I need to move interstate for work. Sadly, this means I don't really have the ability to finish off the conversion. So, up for grabs, all the bits you need to convert an MX5!!! Dropbox full of pics here.
Up for grabs is:
  • Netgain Warp 9 (RRP 3300)
    ZEVA MC600SP (RRP 1314.5
    MES 70/6E Vacuum pump (RRP 511.50)
    CEV Adaptor plate (RRP ~1000)
    EV Works Hall Effect Throttle Box 3-wire, 0-5 volt (RRP 82.5)
    Motor mount bracket
    Battery mount plate
Everything you could need to convert an NA MX5! Just add batteries and go! Something like 6.2k of value, a steal for only 4.9k! Too much? Make me an offer!
Located in Reservoir, can ship at buyers expense.
(Admins please move to for-sale if more appropriate)
Posted: Mon, 03 Apr 2017, 23:36
by evric
Hi woopwoop,
Welcome to the AEVA.
I have updated your Forum profile to "AEVA member".
You now have full access to the For sale section.
Please move / copy this post to the For sale section (depending on what options are available under "Post Options" or I can do it for you...
Regards,
Eric Rodda
Forum Admin and AEVA Membership Secretary.
Posted: Fri, 07 Apr 2017, 00:15
by woopwoop
Thanks for the welcome!
I don't seem to be able to move it, so if you could I'd be very grateful. :)
