That thing that sucks
Post by Richo » Sat, 24 Sep 2016, 00:19
Anybody got any updates, hints or clues to some you beaut Vacuum pump for the brakes?
I'm sure I saw some Billet ali ones a while back but can't find them anymore.
poprock
Real Name: Brian Rockley
Post by poprock » Sat, 24 Sep 2016, 14:17
Hi, purchased a s/h UP28, I think from a Golf, from US for $50A; I have the upper cutout set too high and with a reserve tank 100m dia and 300 long it gives 14 pumps before switching in. The booster is only small (Suzuki Carry). Check out the OHMBOY build on the net.Same vehicle as mine but a much better conversion. Image
TooQik
Real Name: Chris
Post by TooQik » Mon, 26 Sep 2016, 00:45
This is where/what I bought for my conversion:
https://www.summitracing.com/int/parts/ ... /overview/
Can't give you any details of how well it works as it's still sitting in its box due to my conversion being stalled.
poprock
Post by poprock » Mon, 26 Sep 2016, 02:06
Wow, makes a s/h one attractive. Why not trial a used one to see if it meets your requirements?
TooQik
Real Name: Chris
Post by TooQik » Mon, 26 Sep 2016, 05:12
I wanted the larger UP30 over the UP28 and couldn't find one second hand, albeit I didn't spend a lot of time looking.
The UP28 seems to be used a lot in vehicles, while the UP30 is harder to find.
Post by Richo » Tue, 27 Sep 2016, 20:29
Yeah I did see the Hella one's and "unbranded" Hella ones - which weren't much cheaper.
What about the electric cars such as the Lead etc?
Surely they must have something usable.
Quite a few mention that they are only for supplementary use.
ie cars with poor vacuum.
Post by Richo » Tue, 27 Sep 2016, 20:34
To make things worse some OEM vacuum pumps don't clarify that they aren't for brakes.
ebay 310720630307 is actually for the vent controls!
Post by Richo » Tue, 27 Sep 2016, 20:44
331274996988 This one is the UP28 - AUD$203 delivered.
Post by Richo » Tue, 27 Sep 2016, 20:55
TooQik
Real Name: Chris
Post by TooQik » Tue, 27 Sep 2016, 21:47
Richo wrote: Quite a few mention that they are only for supplementary use.
This is why I went for the UP30. To quote from Hella's website:
"These pumps are able to supply the necessary vacuum independent of the engine technology. The UP30/32 supplies a vacuum to the brake booster, and when required, to the engine compartment actuators. The UP30/UP32 is installed in the pneumatic section of the brake system, just like the UP28. Both vacuum pumps are ideal for vehicles without any vacuum, such as hybrid/fuel cell, electric or diesel engines."
Post by Richo » Mon, 03 Oct 2016, 20:39
poprock wrote: (I) purchased a s/h UP28
Any ideas on how noisy it is?
Although it's unlikely I'll hear it over the sub Image
Post by Richo » Mon, 03 Oct 2016, 21:05
Supposedly the VE commode has one.
Wonder how much the wreckers charge for them...
The UP28 appers to be used on the Holden Cruze.
https://www.summitracing.com/int/parts/hla-009428081
http://www.bettabuyone.com/catalog/prod ... q0ml018qn2 $165
poprock
Post by poprock » Tue, 04 Oct 2016, 02:41
My up28 is much quiter than the Gast which was previously fitted. Think of a flock of pigeons passing overhead compared to the Westpac rescue chopper with full pitch.
Post by Richo » Tue, 04 Oct 2016, 13:19
Well I have to get something because I'm too lazy to push hard on the pedal Image
Was on the Hella website and they list 3/4 different models.
The main difference is the UP28 take ~12secs to suck out a 4L to 70% and lasts 600 hours whereas the UP30/UP32 takes half the time but lasts twice as long.
The UP5X is marginally quicker and lasts a bit longer again than the UP30/32.
Post by Richo » Tue, 04 Oct 2016, 20:11
Here are the specs on all the Hella Vacuum's:
Post by Richo » Tue, 04 Oct 2016, 20:19
poprock wrote:I have ... a reserve tank 100m dia and 300 long
So 2.3L.
I have read some other ppl (non-ev ppl) that didn't bother with the reserve tank.
I'd be a bit skeptical about no-tank in peak start/stop traffic.
2L sounds a reasonable size to have.
The tech specs suggest the UP28 is the quieter of the bunch.
Post by Richo » Thu, 10 Nov 2016, 17:49
So I ended up getting a UP28.
Any one know off hand the part numbers for the matching connector?
poprock
Post by poprock » Fri, 11 Nov 2016, 01:28
I used Auto One over the counter fittings. The UP28 is in a container where the 12v battery was originally fitted, so no worries with moisture. The RMS engineer mailed the paperwork today, so hopefully blue slip inspection next week. Rear transmission seal leaking; so will replace first. Still way too much vacuum reserve; must adjust one day.
TooQik
Real Name: Chris
Post by TooQik » Fri, 11 Nov 2016, 04:38
Richo wrote: So I ended up getting a UP28.
If it's the same as the UP30 then the connector should be a Yazaki 7283-5575-10 or equivalent.
Post by Richo » Fri, 11 Nov 2016, 20:44
Yeah that looks like it Image
Shipping alone will be more than any other connector I could shove on there. Image
Or cut One off a wiring loom from a wreck.
Typical
