Hello From Castlemaine
Post by Adverse Effects »
there is 1 sort of direct drive option i have seen and liked but its not cheep lol
torquetrends ev-TORQUE BOX
Madmax wrote:it seems an industrial motor... of acceptable size/mass is limited in speed range?
Johny wrote:Not at all...
coulomb wrote:Pretty much.
Image You guys are funny Image
As Johny points out the motors max (safe) rpm depends on it's balance and bearings.
I'm assuming Coulomb is now referring to the continuous power the motor produces at a given RPM.
So your both right Image
I have pasted this graph in so it's not specific to madmax's issue - it's just an example.
You can compare the "aero power" to the "gear-4 nom" power.
At some point the aero power requirements are higher than the nominal power from the motor.
So in this case it crosses over at ~90kph.
But don't forget this is the "continuous" rating.
You could reasonably expect to go over 100kph for short periods.
High RPM is possible, High RPM isn't a requirement.
EDIT:just noticed 4-th gear data LOL
As I mentioned before the problem won't be the industrial motor.
Anyone can go around the corner and pick-up any aluminum variant from 1/10HP to 25HP off the shelf and have it re-wound and balanced.
The main issue is still you need a "triple-zilla" to run it.
That's why I said you need to look at the motor and controller as a package cost.
Madmax
Real Name: Matt
Post by Madmax »
Big thanks to everyone for showing such interest in my potential ev project!
Is there such thing as a 132L frame?
What are the options with controllers for 132 and 160 frame rewound ac motors?
Post by woody »
I found a link to the ABB industrial motor catalogue here:
http://new.abb.com/motors-generators/ie ... num-motors
https://library.e.abb.com/public/287581 ... 042016.pdf
3GAA132280 is a 15kW 4 pole 132 SMH frame p87
The Torque listed nominal (Tn) is 98.4Nm.
The "Breakdown Ratio" (Tb/Tn) is 2.9. This indicates that the motor can produce about 2.9 * 98.4 = 285Nm Direct Online (DOL) i.e. plugged into the grid.
With a controller you can usually get a bit more.
The dimensions are also in the catalogue p115ff.
Controllers: there is the industrial route (e.g. ABB ACS800 or ACS500)
DIY: http://www.instructables.com/id/200kW-A ... ctric-Car/
Rhinehart: http://www.elmofo.com.au/ac-motor-controllers.html
Tritium and others.
woody wrote: With a controller you can usually get a bit more.
Yes. In the case of Mexy the electric MX-5's motor, about 28% more:
3.8 (a relatively large Tmax/Tn factor) x 72 = 274 Nm; the motor achieved over 350 Nm as shown in the Tritium dynamometer graph on the previous page. 350 / 274 ~= 128%. It's possible that with a more powerful controller and/or battery (the Tritium test pack was a little tired), even more could have been achieved. This is with a "high output design" motor; other motors may differ.
~$12,000 ABB ACS800
~$7,500 Rhinehart: http://www.elmofo.com.au/ac-motor-controllers.html
~$6,600 Tritium
~$3,400 ABB ACS500 (USED)
~$1,400+labour DIY: http://www.instructables.com/id/200kW-A ... ctric-Car/
EDIT:updated prices
TooQik
Real Name: Chris
Post by TooQik »
...and the trailer to cart it around in would only be another $1500.
Madmax
Real Name: Matt
Post by Madmax »
I have a couple of these..... The hearts of 30kw inverters
Although the igbts are probably not suitable for high current low voltage... Rated at 100A
http://www.mitsubishielectric.com/semic ... 24nf_e.pdf
Cm100 are 100 Amp IGBTs - good for about 70 ARMs. Just a bit small unfortunately.
Madmax
Real Name: Matt
Post by Madmax »
Maybe a decent DIY charger...?
Don't know about t a DIY charger. Given the price of batteries I would tend not to trust a prototype charger to take care of them. It really depends how proficient you are at that type of thing.
You could use them to turn the heater on and off?
