Mini or Moke conversion
TasyMoke
Post by TasyMoke »
Can anyone direct me to information specific to converting a Moke to EV?
There have been sightings of a Moke in Perth with what appears to be Sky Energy cells in the back tray.
But no-one is claiming responsibility for it...
Sorry I can't find anything specific that has already been done.
Maybe you would be the first?!?
EDIT: Speeling makes all the duffrence
Tritium_James
Real Name: James Kennedy
Post by Tritium_James »
There's a Mini conversion in Melbourne that's been around for 5-6 years. Custom BLDC motor & controller through a chain drive, and I think it was PbA batteries.
A Moke would be a great conversion. If you are mechanically adept a modern FWD train while getting rid of the gearbox-in-sump while you are at it. The Moke has all that space in the side cavities which would be good space for part of the pack.
You would have to start with a good one to make the project worthwhile.
There are two 1960's Minis on evalbum - one in NSW, one in NZ.
http://www.evalbum.com/2407
http://www.evalbum.com/1715
Post by woody »
There's a moke conversion underway in Sydney, but I've only heard 2nd hand. Headway batteries. There is also another Mini conversion completed fairly recently in Sydney, my friend's boss's. Conversion done by Thunderbolt I think - DC / ThunderSky?.
seligtype3
Real Name: Jem Freeman
Post by seligtype3 »
Mini would be great! Almost chose to do a Mini panel van before going VW. Didn't come across too many examples in early research. What's the GVM on a moke/mini?
Restoring and converting a 1969 VW Type 3 Variant.
Hmmm it says controller limited to 320A(8C) for 112kph will go much faster unlimited.
144V pack
72V loss for 320A
is 23kW
Does this sound correct?
Jeff Owen
Real Name: Jeff Owen
Post by Jeff Owen »
[quote="What's the GVM on a moke/mini?[/QUOTE"]
From memory, 1000kg
EV2Go
Post by EV2Go »
Johny wrote: A Moke would be a great conversion. If you are mechanically adept a modern FWD train while getting rid of the gearbox-in-sump while you are at it. The Moke has all that space in the side cavities which would be good space for part of the pack.
Thanks Johny I was looking for 2407 on these forums but couldn't find it. He also has a youtube video http://www.youtube.com/watch?v=g9BL0qtt8Gs
gttool
Real Name: Geoff OToole
Post by gttool »
I am currently in the process of converting a Moke with no gearbox
it is a little tight but will all fit very neatly
i am using an r160 diff and 17r costov with a blower belt drive showing through the grill
will have the motor and diff assembly finished and test fitted to the car by the end of next week hopefully (between other jobs )
the side pods do make good battery boxes but not quite enough room will fit about 96 headways in each side and 80 in the front or could go between the rear subframe but more weight in the front would be better
david s
Post by david s »
Have often thought of using a Moke as a hybrid elec. by removing the back axle assembly and replacing it with a complete rear axle, including the diff, from another small car. This way an elec motor could be coupled to the diff and the original motor and gearbox can be left intact. The generator could also be used to charge the batteries. The vehicle would then have tons of range, could be used as elec only or ICE only, or both, giving it also a 4WD capacity.
gttool
Post by gttool »
sounds like a plan but would have trouble getting it registered as it wasn't originally 4wd
but staring with a small 4wd would work
eg suzuki 4*4 chassis with a moke body !
david s
Post by david s »
"sounds like a plan but would have trouble getting it registered"
That's the main reason i built an electric bicycle. No reg. licensing or certification.
roddilkes
Real Name: Rod
Post by roddilkes »
Darren Hamley has converted a Moke in Perth. He drives it every day and it is a great conversion. Mokes are very light weight and have plenty of space in the back for batteries, very simple.
I suspect the crash safety rating would be somewhat less than a Jumbuck (which apparently is not saying much ;)
Post by woody »
Being rear-ended by a 4WD in a moke I imagine is a once in a lifetime experience. (very near the end of your life)
Richo wrote: There have been sightings of a Moke in Perth with what appears to be Sky Energy cells in the back tray.
roddilkes wrote: Darren Hamley has converted a Moke in Perth. He drives it every day and it is a great conversion. Mokes are very light weight and have plenty of space in the back for batteries, very simple.
Yay I'm not insane Image
gttool
Post by gttool »
The Moke i am converting is nearly finished and there will soon be sightings on the east coast have posted some pics on the Mokes Inc forum
http://www.mokesinc.org/index.php/topic,7783.0.html
Geoff
EV2Go
Post by EV2Go »
There's only one question left to be ask... is it under-driven or over-driven Image
Tritium_James
If the system is actually capable of 150kW in a Moke then I'd say it's over-driven!
gttool wrote: The Moke i am converting is nearly finished and there will soon be sightings on the east coast have posted some pics on the Mokes Inc forum
Geoff
Nice to see someone else using Headways - I don't feel so alone now Image. Very neat wiring Geoff. What did they mean by a "Choke" loom?
gttool
Post by gttool »
I think its a little bit overdriven
electric cars dont have to be slow!
a choke loom is a Chinese Moke loom quite well made compared to the original except it doesnt come with a wiring diagram and you have to work it all out yourself
headways will be good but a bit of work
finished the wiring and the wheels turned on sunday
just needs the battery packs fitted now
I like pictures Image
Edit: here they are - sorry!
gttool
Post by gttool »
The mokes going !!
The timing belt makes a distinctive sound but is not annoyingly noisy it is very smooth and no vibrations as per the original ice
the motor and diff is solid mounted to the subframe also
Would happily accelerate over 100km/h without any problem at a max of 200a   the gauge is not calibrated yet so I don’t know if that is completely correct
Brakes need a good bleed and windscreen needs a clean
The controller got warm to touch the motor got a little warmer 5 seconds touch is enough this was straight after 100km/h run and straight into the shed
much nicer to drive than the original ice powered car i must say !
Sweet Image
el_gallo_azul
Real Name: Greg Flint
Post by el_gallo_azul »
Hmmm that's a shame. I was as keen as mustard to see http://www.mokesinc.org/index.php/topic,7783.0.html but it looks to me like http://www.mokesinc.org is completely gone.
Is similar material now anywhere else?
