TIG welder needed
zeva
Real Name: Ian Hooper
MSN: sigmunky@hotmail.com
TIG welder needed
Post by zeva » Sat, 22 Dec 2007, 21:39
Shortly I'm gonna need to find a talented TIG welder to weld together the
aluminium subframe in my MX5. Anyone know of such a tradesman?
(I'm happy to pay the going rate of course, I just don't know anyone with the
skills..)
Ian Hooper
http://www.zeva.com.au
zeva
TIG welder needed
Post by zeva » Thu, 17 Jan 2008, 10:09
*bump* Anybody? (In WA, by the way!)
OK a couple of other things on the subject, as I've really gotta get onto this fabrication asap.. Anyone know a good place to buy sheet aluminium in WA? I'm after a couple of square metres of 3mm thick, and about one square metre of 12mm.
And lastly, suggestions for a good way to CNC cut the aluminium into arbitrary shapes? Jetcut down in Canning Vale could certainly do it with their waterjet cutter, but plasma is probably cheaper.. but I don't know of any CNC plasmas for hire.
Ian Hooper
