Toyota Prius Copper Bus Bars - Tin or Nickel Plate
Phildo
Real Name: Phil
Post by Phildo »
I need to rebuild some Prius hybrid batteries, and would like to ensure that the copper bus bars don't build up corrosion in the future.
Options:
1) Just clean the bus bars.
2) Get them nickel plated (commonly done in the US for hybrid battery rebuilds).
3) Get them tin plated (an option put to me by someone who does a lot of stuff for aeroplanes).
The 2003-2009 Prius has a habit of developing small cracks in the roof, near the corners of the tailgate. This results in a build-up of water in the spare wheel well and around the 12v battery. This creates a source of moisture/humidity right next to the hybrid battery.
Is tin plating a suitable option for the bus bars? Or, is nickel plating the only suitable option? (ie tin plating is apparently much cheaper)
Does anyone have any recommendations on plating options/places in Perth?
Hybrid battery and spare wheel well/12v battery proximity:
The water in one Prius which I recently worked on (and yes, the 12v battery was well and truly deceased):
Cracks that commonly develop in the Prius roof, and then leak water into the Prius back area:
[ Edited Coulomb: Coppy -> Copper iin title]
Re: Toyota Prius Copper Bus Bars - Tin or Nickel Plate
Tin has 0.65V and Nickel is 0.30V.
Most copper lugs are tin plated.
My preference is Nickel plating.
But most of the local people that do this are for small one off consumer goods / art not industrial battery busbars.
I did contact these people some time ago about plating busbars but never actually used them.
They do both Nickel and Tin.
http://www.silverplating.com.au/services/index.html
Phildo
Real Name: Phil
Post by Phildo »
Conclusion: The advice that I got from a plating plate in Maddington was that if I can get new nickel-plated busbars for a reasonable price then to go for it - plating them here was going to cost more than buying them from China.
I bought from: https://www.rhibusbar.com/product/nickl ... sbars.html
I paid $US75 + $US50 freight (ie $US125 total) for 220 bus bars (ie enough to do 8 Prius batteries with a few spares just in case).
So they were already premade for the prius? That's lucky
That link looks quit good.
I see they do custom ones.
I'll have to give it a go on my leaf cells.
