Reducing charging amps on Clipper Creek model
Gazza
Real Name: Gary Crighton
Post by Gazza »
Hi, I have a Clipper Creek 16 amp home charger a although it is possible to use the cars control display to reduce the charge intensity of the standard BMW supplied 8 amp charger, this appears not possible with the bigger 16 amp charger. Anyone know of a way around this short of purchasing another aftermarket charger???
