Lithium Titanate (LTO) Batteries
Post by Richo » Thu, 12 Jun 2014, 21:01
Not much on AVEA about the LTO batteries so far.
They are 2.4V have high C rates for discharge AND charge.
They also have really good cycle life - better than LeFePO4.
One manufacturer is claiming 16,000 cycles Image
Mitsubishi put the Toshiba SCiB's in "some" Mievs'.
The down side is they aren't as energy dense as some.
So an ev wont have as good range.
But will charge in next to no time!
http://en.wikipedia.org/wiki/Lithium%E2 ... te_battery
The link below has them in 18650 size that are radial PCB mount.
Just don't run them through the wave machine. Image Image
In comparison they are about 10x the price of Headway cells per Wh.
http://www.batteryspace.com/Lithium-Tit ... ttery.aspx
Post by Richo » Thu, 12 Jun 2014, 21:10
And here is the race car using the LTO batteries.
10min recharge with 32kWh pack (250kW charger!!)
http://www.raceabout.fi/era/home
Post by Richo » Thu, 12 Jun 2014, 21:20
And a data sheet for an LTO.
20 year life span
15,000 cycles to 85% capacity. (seems real as UPS has 50k+ cycles to 50%DOD)
Up to 100+ C discharge (Mmmm someone may have to validate that!!!)
Safe to over 200 Deg C
http://www.evcanada.org/pdf/NanoSafe.pdf
Post by Richo » Tue, 17 Jun 2014, 15:54
Now A123 have acquired some IP from Leyden Energy and some of their techs.
So it looks like A123 are now trying to expand there battery chemistry to include LTO batteries.
Here is A123's press release from yesterday.
http://www.a123systems.com/c956a138-546 ... detail.htm
7circle
Real Name: Ken
Post by 7circle » Thu, 23 Oct 2014, 22:16
Link to archived EIG data sheet on elthion liionbms.com site.
Li-Ti Charge fast http://liionbms.com/pdf/eig/ePLBQ.pdf
60Wh/kg for 2.2V / 12.5Ah cell
But continuous 6C charge and 10C discharge
unheardofinstruments
Real Name: ron Berry
Post by unheardofinstruments » Wed, 04 Nov 2015, 14:00
I have only seen these used by lightning car company
http://www.lightningcarcompany.co.uk/Li ... /home.html
Lithium sulphur batteries look promising too
http://www.steatite-batteries.co.uk/oxis-energy.html
Lithium Sulphur Topic here
[Edited by Admin to make the links "clickable" and add link to LiS topic]
