Tell your grandmother how to suck eggs. That wouldn't happen to be the EVSE that is limited to 6 amps that started this thread would it?acmotor wrote: Tell Mrs Weber that she can buy an EVSE from holden for $350 while you try to re-invent the wheel with lesser features.
What an EVSE provides
- weber
- Real Name: Dave Keenan
- g4qber
- Real Name: Joseph
When plugged into imiev or leaf the holden EVSE outputs around 10A, it is just that the volt defaults to 6A to be safe
then the user has to select 10A
if the volt has a EVSE that negotiates 15A with it, the 6 and 10A options are not operational, even though the touch screen buttons are present.
the way to determine which level the volt is charging is to look at the time to complete.
eg.
6 hours at 10a
10 hrs at 6a
4 hrs at 15a
note that only 10kWh is usable on the volt in EV mode
hence it only costs $2.50 to charge and some people wonder why the volt charges so much faster.
4 hrs vs 8 hrs for the leaf/imiev
eg.
6 hours at 10a
10 hrs at 6a
4 hrs at 15a
- acmotor
- Real Name: Tuarn
I understand the Volt EVSE does 6A and 10A.
The Volt vehicle itself defaults to 6A but the user can upselect to 10A on the touch screen.
Joseph can you confirm that ? What current did the volt EVSE supply to iMiEV when you tested it ?
edit: typing at the same time !!
edit: $350 seems a poultry sum for an EVSE with J1772 connector
- g4qber
- Real Name: Joseph
the BMW i3 is supposed to be about the same size as the imiev and cost a fortune due to carbon fibre
I suppose one is willing to pay for beauty and less weight
apple is testament to this.
the imiev is like Dr Who's TARDIS. doesn't look like much but it does the job
the Master's functional chameleon circuit TARDIS looks better.
the imiev is also like a PC; it does the job and is for the masses.
BMWs are like Macs and you pay for the privilege
Jordan at MacWorx Joondalup commented that it is quite big on the inside.
- g4qber
- Real Name: Joseph
the holden EVSE outputs around 10A to the imiev and Brian's leaf
the betterplace mennekes to j1772 cable also doesn't have a hole for a padlock.
http://shop.zerocarbonworld.org/cables/ ... cable.html
200 pounds for a cable, holy @!# batman.
this is the Master cable lock
http://www.bunnings.com.au/products_pro ... 20338.aspx
i need to use the correct term "coupler" in future. i had been calling it the trigger.
http://www.ittcannon.com/download/sample/647
personally i prefer the yazaki grey 32A as it is lighter.
check out the damage to this coupler though.
http://www.plugincars.com/why-baltimore ... 27614.html
- g4qber
- Real Name: Joseph
http://www.pluglesspower.com/
who needs couplers when we have inductive charging?
but there is power loss
i guess that this is similar to wifi vs cable.
if you want speed / no power loss, plug it in.
- g4qber
- Real Name: Joseph
http://www.goauto.com.au/mellor/mellor. ... 450017732E
Ross blade with j1772 connector in picture.
Not sure if electron needs an evse or behaves like 2010 imiev
For $300,(ebay no. 171083777707) there are a couple of Clipper Creek 240V 16A EVSE's
Is anyone familiar with ECS-16-C5-L12-26 configuration on this model?
- weber
So why would the "wise Mrs Weber" pay any money for yet another device whose job is to prevent her Leaf from charging at its full 15 A?acmotor wrote: I understand the Volt EVSE does ... 10A.
Those must be expensive chickens.edit: $350 seems a poultry sum for an EVSE with J1772 connector![]()
- acmotor
- Real Name: Tuarn
Agreed that 15A charging is desirable at times.
It does remind us that the Leaf needs to charge on 15A for the same amount of time as an iMiEV charging on 10A to do the same range.
As a matter of interest, in the pic of your PV and EVs, what was the PV output on the overcast day compared to the charging EVs ? Will you EV charge during the day to use actual PV power ? What is your thinking there ?
- weber
Don't know. Sorry. The total nominal PV array power is 6.5 kW. It should average about 20 kWh per day over the year (I have a winter shading problem to the west). The Leaf battery is 24 kWh, but I expect its average daily charge requirement to be less than 8 kWh. And the rest of the household will probably chew up the other 12 kWh per day (two teenagers).acmotor wrote:As a matter of interest, in the pic of your PV and EVs, what was the PV output on the overcast day compared to the charging EVs ?
So long as we're still getting paid 50c/kWh for net exports to the grid, we're not planning to charge during the day. But we're being good network citizens and avoiding the evening peak too -- only charging between 10 pm and 7 am using the Leaf's charge timer, even though this doesn't save us any money since it's on the non-time-of-use general domestic tariff.
- acmotor
- Real Name: Tuarn
Makes sense. Sort of.
Just musing the numbers... tell me if I've got it wrong. I know you won't hesitate.
Using WA prices...
I charge EV offpeak 9pm to 7am (timer set to 11pm to 6am) at 14.5559c/kWh
You charge EV at 29.403c/kWh in QLD yes ?
You export 8kWh (say) at 50c/kWh = $4 (is the a GST component ?)
You buy back 8kWh to charge EV at 29.403c/kWh = $2.35 so you are ahead by $1.65, good.
The same 8kWh costs me $1.16 off peak.
So $2.35 - $1.16 = $1.19 more for your charge. You get $1.65 back so all up you are 46c per day ahead. (don't spend it all at once!)
I can see why you don't want to pay money for an EVSE !!! The economics as they stand of PV aren't that friendly.
It seems the 50c/kWh is not that generous !
Using WA prices...
- weber
I fail to see how this comparison is useful given that WA and QLD tariff structures are different, and I'm not sure it has any bearing on the topic of this thread. Rest assured that I have done the relevant calculations for QLD. You also need to consider the fixed daily service fees and the regulations about what can and can't be connected to various tariffs.acmotor wrote: Makes sense. Sort of.
Just musing the numbers... tell me if I've got it wrong. I know you won't hesitate.![]()
Using WA prices...
<Hypothetical calculations deleted>
A non sequitur. You appear to continually fail to see why I don't want to even have an EVSE, let alone pay money for one. I'd pay money to not be required to have one, and I'm working on it.
- acmotor
- Real Name: Tuarn
If I keep stirring you will come up with an open source $10 EVSE... or give in and buy a commercial model for your Leaf.
Nice side step on the PV feed in topic ! Yes, off topic. But you get economic point ? I would add that the power authorities will increase the very supply charge you allude to to eventually make the 46c disappear too ! I'm not against PVs, I have some and a WT, It is just that the economics are not that rosey.
- weber
Acmotor, have you ever plugged your portable EVSE into an extension lead?
weber wrote: Acmotor, have you ever plugged your portable EVSE into an extension lead?
The evidence suggests that Acmotor at least has the means...
- g4qber
- Real Name: Joseph
Clipper creek is 120v 15a
I am so glad I don't live in America where their power is rubbish.
- Adverse Effects
- Real Name: Adverse Effects
its like 1/10th the price compared to hereg4qber wrote: Clipper creek is 120v 15a
well maby not 1/10th but its a hell of a lot cheaper there
a friend in the usa has a EV and it costs him 30c(his math not mine) to charge it from flat
Last edited by Adverse Effects on Sun, 28 Jul 2013, 19:24, edited 1 time in total.
AC,
Weber has an evse because he must have one. He doesn't want one. This is what I am saying.
Because the power authorities (the Government acting as a corporation - never mind that we are the shareholders as well as the customers), but probably eventually a corporation acting as a corporation (which will have a select group of shareholders (and perhaps no shareholders if they make enough money to buy back shares - depends on competition (like fuel and supermarkets) and whether the government of the time thinks that it is good for the population to not be involved in power production) - in time, if either side stay in power
, the power authorities will always win and they will reduce the tariff for solar, maybe to nothing, and prices will rise anyway. When this happens, anyone with panels (and possibly roofs painted with power-generating compounds), will naturally charge their cars during the day (no point being loyal to a disloyal power company (should this happen
) and anything else they have.
Then it will become worth it, and probably easier, to store any excess solar-generated power.
Naturally, the authorities, not wishing to be seen to raise taxes, but instead to milk the power companies (and blame it on other costs) will have to raise the price of power (because of all these electric cars using their power (not) and the general population will agree with the power companies and be unhappy, and vote the government which can best convince the non-ev population that they can best 'fix' the situation.
Think it would make a novel? Oh well, maybe the next one.
So, AC, if you could get an evse with your car (because it comes with one anyway (standard equipment)) or use a 32amp single-phase plug and charge at 20 amps because that's what you choose, what would be wrong with that? would be wrong with that? wrong with that? ?
And why do you care so much? If you'd invented the aeroplane, they could not have flown, until they were safe enough - for the future of the aeroplane industry,... it seems.
- acmotor
- Real Name: Tuarn
Nothing wrong with that, as long as the safety and standardisation is up to scratch. In fact if you use a standard like J1772 you'd be covered !
I have said time and time again that the safety features and standardisation of an EVSE are to be respected (like every production EV sold in Oz so far uses it). If you DIY that's fine. The J1772 standard is there in your face. There are open source kits etc. There is public charging to that standard. The world may go for another standard altogether in the end, but it will always be better than a domestic 3 pin plug and lead ! (...just picturing a Leaf with a caravan plug on the nose
Who said 20A, not me ? Leaf and iMiEV max is 15A. edit: next Leaf 32A ?
Extension lead ? Yes is the answer, as coulomb posted.
Follow my signature for the full docc on the myth busting of extn. leads. Actually, I don't normally use one.
I was assured by weber that it was fine to plug into any 10A sockets etc.
- acmotor
- Real Name: Tuarn
?? Production EVs have not been held up by safety standards for charging ? J1772 was engineered and they got on with EVs. I don't get your point.
Having an emotional resistance to the technology of EVSEs may be a hold up. You are right there.
AC, I think a few of us have differing opinions on our best future.
No problem. Goodnight.
- weber
The portable EVSE that comes with the Leaf has a tag on its cord near the plug saying "Don't use an extension cord or adapter" in 6 different languages. So the myth you're busting comes via the car manufacturers, and good on you for busting it. With the switchboard and wiring standards we have in Australia it is indeed little more than paranoia.acmotor wrote:Extension lead ? Yes is the answer, as coulomb posted.
Acmotor, if or when you use your portable EVSE without an extension lead, and the powerpoint is more than 600 mm from the ground or floor, do you consider it unsafe the way the weight of the EVSE tends to pull the plug partway out of the socket?
I don't expect you to agree, but I hope other readers can see that if it's OK to plug your EVSE into an extension lead, the logical conclusion is that it would also be OK to have the EVSE built into the car, in which case the combination of J1772 EVSE controller and J1772 EV controller could be replaced by a simple interface in the car for choosing how much current to draw.
To make this foolproof it could be based on resistor-coded plug adapters as I suggested, using a fourth wire that I will call the "sense" wire from now on, to avoid confusion with the J1772 pilot wire, and to suggest that it makes more "sense" than tying a brick to your plug.
- g4qber
- Real Name: Joseph
http://www.clippercreek.com/products.html
Clipper creek does seem to make 240v 15a evses.
One had to be wary of the ones on eBay as they may be 120v 15a.
Until today I hadn't come across the 240v model
- g4qber
- Real Name: Joseph
Perhaps those who don't like evse bricks could buy the 2010 imiev. This doesn't come with an evse.
It is might be similar to Ross blade's j1772 electrons. I shall email him about this.
