I can partly answer some of your questions.
EvGoRetro wrote: ↑Wed, 11 May 2022, 20:07
- Would someone share their experiences of installing and using a decent 6.6 kW on board charger- Maybe Elcon HK-J series or similar? (If no experience, then a decent opinion will do!)
I don't know if I'd class the newer ultra high frequency, ultra compact Elcon chargers as "decent". One user had a lot of trouble with them, I thought it was
@Paulvk but I can't find the post now. [ Edit: Actually it was Paul9; see
this post. ]
@jonescg used one in the Prelude conversion, and it seems to work OK, as long as the power source is capable of about 30 A.
- What do I need to know about connecting to the big wide world of Public Chargers? (Do I need to 'talk' with them? Or does it just 'plug in'?
There is a small amount of "talking" required; you can't "just plug in". There is a small module, the
AVC2, which is designed for doing this "talking" for DIY conversions, but there seem to be problems. See Chris Jones' posts on the Prelude conversion, starting about
here. You might be able to read earlier posts and find the post where he selected the Elcon; I could not quickly find it.
There is little hope of connecting a conversion to a fast (50 kW+) DC charger. The handshaking is very complex, though Damien McGuire was attempting it using used BMW parts. Note that many DC fast chargers won't charge a battery under 200 V, though I believe that the fairly common (at least in Australia at present) Tritium RT 50 kW will charge from 50 V upwards. A 27 kWh battery probably doesn't need DC fast charging, even a higher-end vintage conversion. But the ability to charge at public type 2 "chargers" would be good in a higher-end conversion.
MG ZS EV 2021 April 2021.
