Power output question...
Tritium_James wrote: Richo, of course they'd pass your BMW at the registration office. The rewound motor nameplate says 22kW! Image
True Image
Now where shall I put the woody button?
Actually I could probably be use a combo of the fwd/rev switch, brake and accelerator pedals.
The Woody button should be the horn.
how about "the red button" MIB style
Gemini
Post by Gemini »
Tesla Roadster Dyno Range Testing video. This shows some of the initial range testing for the Tesla Roadster on the dyno. Just posted this video for youtube users to see some of the dyno testing. From "Miles of Progress" by Andrew Simpson (Vehicle Systems Engineer) in Tesla Motors Blogs May 10th, 2007.
On September 24, 2007 the Tesla Roadster achieved 221* miles on the combined EPA cycle on a single charge.
The full numbers are:
230 mi EPA city
211 mi EPA highway
221 mi EPA combined (city/highway)
Specs:
0-60 in 4 seconds
248 hp @ 8500 rpm, 211 lb-ft @ 0 rpm
2690lbs
Efficiency (Plug to Wheel):
(221 miles/ 68.51kWh**) * (33705kWh/gallon) = 109mpg
*Update: Due to a wrong calibration on the dyno, the EPA range was overstated to be 245. The new result was updated on Dec 27, 2007.
**Based on 31kWh/100miles figure supplied by Tesla on their blog; charging inefficiency is already factored in, 31kWh is energy measured from the plug, not battery.
Real world mileage haven't changed, as the error was due to calibration not the actual efficiency of the car.
Real world mileage was "as high as 267 miles per charge in slow city driving to as low as 165 miles in aggressive highway driving."
Visit teslamotors.com for more info on the car.
http://www.youtube.com/watch?v=K6uiAI8k5yk
Found this on youtube for you. No graph though :(
htial
Real Name: Laith
Post by htial »
230 mi EPA city
211 mi EPA highway
Specs:
0-60 in 4 seconds
2690lbs
I wish the graph was there...   ...It could have just bean coasting...   ...I think the fan for the "radiator" was louder...
