Advanced DC L91-4003
ShaDoW
Real Name: Chris Mallett
Post by ShaDoW »
Can I use this in a motor bike?
Hi all I am new to the whole EV scene I am looking to build a EV motard I have a short comute less than 20km round trip to work 5 days a week looking torque and fun while blasting to work
any ideas? I am looking to go down the road of getting a basket case ICE bike and modding it to be a EV in QLD (I live in Mount Isa)
tips?
Hi. It seems a bit large for a bike - depends on the size of the bike, I initially considered it for a small car. Have a look at the conversions on www.evalbum.com (if you haven't already) and see if there is a trend there. Use the search tab at the top to limit it to bikes.
lithbattboss
Post by lithbattboss »
I presently have two customers in the USA who are undertaking electric motorcycle conversions. These guys are quite experienced with EV's. They are using my 20C discharge BMI cells with a Perm pancake motor. The information they sent me on the motor they have selected is here-
http://www.electricmotorsport.com/store ... pmg132.php
It looks like a good size motor for a motorbike project with heaps of power.
I would be happy to forward you info on the progress of their projects. They will be sending me photos during their builds.
I also have a customer in europe who is building the world's fastest e-bike. This bike has a top sped of 90kph. Pretty scary really considering this is a bicycle and not a motorbike!Image
Where power matters.
www.lifetechlithium.com
Gow864
Real Name: (John) Gary
Post by Gow864 »
ShaDow. check out Endless-Sphere. there are heaps of MC conversions there. Well worth a look
Electrocycle
Real Name: Andrew
MSN: dumhed@dumhed.com
Post by Electrocycle »
I have an A91-4003 which I'm about to test out for possible use in my bike.
From what I've experienced and seen, I think the Perm motor is probably one of the best for the job, but they're not cheap.
I'm looking at using a gearbox too, because to get a high enough top speed with direct drive, you need massive current to get your take off torque - which reduces efficiency quite a lot.
gttool
Real Name: Geoff OToole
Post by gttool »
I have just got a perm motor for a bike they are not cheap but you get what you pay for
Am going to stick it in a gocart before i do the bike
I am also looking at building a two speed gearbox for the bike with a 5:1 and 1:1 giving 0 - 60, 0 - 120 km
originally wanted to use a planetary gearbox but will end up being a conventional type dog box.
If you want to have a look at the motor pm me
Geoff
Electrocycle
Real Name: Andrew
I'd be interested in what gearbox you're planning on using.
I'm looking at options for that at the moment :)
gttool
Post by gttool »
I would build one from scratch to suit the application
it would slide over the motor shaft
the drive direction will then be correct for most applications won't need an idler
the output shaft would come 100mm or so back which makes the sprocket in a better position
would make this shaft to suit a standard motorcycle sprocket
would possibly make the gears interchangable to begin with to change ratios in the box.
how does that sound ??
Geoff
Electrocycle
Real Name: Andrew
that sounds very nice :)
Feel like making another one?
I think you'd probably only need 2 or 3:1 reduction in the low gear if you're using a normal bike sprocket setup for the final drive.
roddilkes
Real Name: Rod
Post by roddilkes »
This motor is a good choice for a bike.
Compact, lightweight with easy DC control.
You could do direct chain drive as it is fairly torquey.
One of the WAEVA members has one in a baby car and it goes like the clappers.
No regen braking though.
Michael (Doc) Symons is the one to talk to about these motors, he has been using and selling them for 20 years.
whatisthis
Real Name: Glen
Post by whatisthis »
Which motor the PERM or ADC?
Have a look at how it has been done in the Quantya Trek http://www.quantya.us/
What 7 to 11 kW AC motors are available locally?
In 7.5kW there are CMG, ABB, Trojan and probably WEG - all aluminium frame. In 11kW there is ABB (59kg) and Trojan (67kg).
Google CMG Motors and follow links to aluminium frame. On ABB web site it gets a little involved but specs are all there. Post if you can't find them and I'll delve further. Google Trojan Motors for theirs. There are also 5 or 5.5kW which may be sufficient - some have 3.5 pullout torque which get close to the 7.5kW.
