Ive spent sometime using my auto nerdity choosing a potential WhiteZombiesque combination for a successful DoorSlammer.
The following is a shortlist from tons of vehicles considered.
Fiat 500 or Niki 550kg as raced by Rigoli in the past
Datsun 1000 625kg (lighter than WhiteZombie 1200 by at least 70kg)
83-85 Suzuki Hatch 550kg (4wd available therefore Rwd a sinch)
Please note: Had to be a sedan like car no sports cars like an unoffordable
640kg lotus elan or a VW buggy based which is limited in many racing classes.
After carefully considering the weights and availability,
the 1984 Suzuki hatch came trumps. Avail in FWD in Oz they still have
the provisions for RWD built in, eg tailshaft tunnel and rear leaf
spring type suspension. Suzuthiasts have converted to rwd using a suzuki
carry differential and all bolts up (but not strong enough for racing).
So this thread is about making a Suzuki Hatch
into an Electric E 1/4 mile beast.
So lets start from the diff and work our way forward...
An all-alloy quickchange rear end to handle the abuse and stay lightweight.
26-30kg using nissan pintara rear disc brakes $3000AUD
Rear tramp bars for better traction under acceleration
$300AUD
Change front disc brake assembly to Nissan Bluebird S3 setup using bigger discs and calipers. Easily sourced from wreckers #300AUD
Custom balanced short tailshaft $300 AUD
Now the gritty bit
Option 1. Direct Driven 11 inch Ge motors 1000USD each from forklift suppliers modified by someone for high voltage. eg 208 volts
83% efficiency at motor and 90% efficient controller 200-250 hp possible - controller choice unknown.
Option 2. Siamesed 9 inch motors at 192-208volts - controller unknown
Other options?
Remember the Direct driven motors setups are based after learning what Master Wayland has tried (just bigger combo Siamese -
more lamination area more potential)
batteries options??
eg. 16 x 12V = batteries that can deliver 1200amp discharges safely for 15 seconds?. Optima Blue Tops? others?
Weights
Suzuki hatch total weight with ICE gear 550kg
Motor and complete tranny 95kg.
Gas tank, radiator, fluids, exhaust 25kg
550-120kg= 430kg.
add 30kg alloy Winters quickchange 30kg
add tailshaft 5kg
add 11inch motor 80kg
add controller (eg Zilla no longer avail.) 15kg
add misc 30kg
add batteries ? (eg 16 x 12v bluetop optimas 288kg)
total around 880kg or 1930lbs
The thing that must not change is the vehicle although short wheelbase a mistupidshi ICE 2.6 astron turbo powered version has run into the 9s
(thats one of the heaviest 4 cylinders around more like a 6 cylinder in weight)
The rear hatch is very heavy for this kind of car so around 15kgs
could be saved there by replacing with lighweight FRP version in no way
sacrificing structural integrity of chassis. This is to save weight when
a rollcage will need fitting in the low 11s.
Other weight savings could be made where removing rear seat and stripping the interior from heater and other bits so another 20-25kg is possible.
