I'm in the process of converting an old 125cc Suzi.
I'm using a mars electric and a 48V/40AH TS battery pack, Kelly brushless 300A controller (I'm going it limit to 3C). Can I work out what it's Wh/km will be? approximately?
Gow.
Wh/km
- Richo
- Real Name: Richard
Wh/km
This seems to be a reoccurring problem.
Finding bike aerodynamics is worse and highly variable due to the rider.
Don't forget the Wh/km will vary depending on speed.
Here is a typical sample but as I say yours will be different.
Antiscab do you have any actual running data that could be used as a guide?
- Real Name: Matthew Lacey
Wh/km
Hi Gow,
i can give you a data point.
on my emax i get an average (since last week when i started recording) of 43.7wh/km at sustained speeds of 60-70kmh including head winds and hills.
from the mains my average (for the past week) is 64.1wh/km.
