new forum
poprock
Real Name: Brian Rockley
new forum
Post by poprock »
Hi; With regard to the DIY EV debacle, I notice that several contributors to this forum have posted, all with negative comments. Some ten days ago I posted giving support, moral and financial to starting another independent forum to distance ourselves from the VB raiders. In the past I have had issues with a wandering IP being blocked and requiring verification. This only happened after the takeover. Now I find that the verification process to allow log-in and posting is impossible to use. Am I channelling Ozzy Osbourne and his paranoia thinking that I am blacklisted, or am I a boofhead who shouldn't be allowed near a computer or all of the above? It would be nice to have the old forum back :evil:
Re: new forum
poprock wrote: Fri, 27 Jul 2018, 11:11With regard to the DIY EV debacle, I notice that several contributors to this forum have posted, all with negative comments.
are you talking about this forum? i havent seen that but i havent read every post here
your last post here be for this one was 07 Jun 2018 17:03 that is 20 days ago (2 times what you said)
unfortunately that is the new software they moved to :-( (i still liked the old forum software better)
takeover? conversion would be more accurate i think
again new software :-(
yes you are (oww come on i am just kidding you opened the door for me to do it LOL)
yes i would like it back to but that is life :-(
Re: new forum
I think Brian is referring to the DIY ElectricCar forum, and it's problems.
poprock
Re: new forum
Post by poprock »
Hi, after a lot of detective work in the settings I discovered one that requires IP verification for each logon. The box was ticked so I unticked and hey presto! problem solved. I am not smart enough to have set that in the first place so go figure? :o
Re: new forum
poprock wrote: Sat, 28 Jul 2018, 18:11 Hi, after a lot of detective work in the settings I discovered one that requires IP verification for each logon. The box was ticked so I unticked and hey presto! problem solved. I am not smart enough to have set that in the first place so go figure? :o
good to hear you got that problem sorted
