Offer for all members Friday 9am WST
Posted: Wed, 20 Jun 2018, 12:54
by reecho
Hello all,
For anyone who is interested in EV Conversion and/or DIY Energy Storage at home the AEVA has an offer coming up which should excite..!!
It is only open to AEVA financial members. Numbers of items on offer will be distributed based on membership numbers per state and it will be on a first come first served basis.
This is a one off chance folks. So please register as a financial member if you haven't already and are keen.
An email will be sent to members 9am WST with details of the offer.
NOTE: This offer may be withdrawn at any time
Re: Offer for all members Friday 9am WST
Posted: Fri, 22 Jun 2018, 09:03
Details of the home storage battery offer!!!
Brighsun LFP spec sheet.pdf
(951.73 KiB) Downloaded 167 times
Posted: Fri, 22 Jun 2018, 16:29
Wow.
So that's been an interesting day of answering emails...
AVASS were the company building the Brighsun electric bus in Melbourne. Sadly, the bus project fell through and they had 1.7 MWh worth of LFP batteries in need of a home. They very kindly contacted our association and offered us first dibs on the cells. They are too low C-rate for a vehicle, but perfect for a storage battery, so we divvied them up and made sure each branch got a fair allocation of battery packs.
Unsurprisingly, the 23 kWh battery packs were snaffled up very fast (only 1 left allocated to the ACT) but there are still a few 11 kWh battery packs left in Tas, Vic, Qld and NSW, and one in the ACT. I look forward to seeing them get built into some awesome projects here soon!
Posted: Fri, 22 Jun 2018, 17:11
jonescg wrote: Fri, 22 Jun 2018, 09:03 Details...
They are the sparsest of details. What I'd like to know is
* Terminal spacing (I'm hoping for 106 mm)
* Thread size for bolts (e.g. M8 or M10)
Any chance of those numbers? I'm more interested in the 220 Ah cells at this stage, but information for both would be really handy.
Posted: Fri, 22 Jun 2018, 18:54
220 Ah battery images:
Posted: Fri, 22 Jun 2018, 18:56
440 Ah cells:
460 L.jpg.jpg (100.66 KiB) Viewed 3086 times
460 W.jpg.jpg (101.45 KiB) Viewed 3086 times
460 Ah H.jpg.jpg (112.73 KiB) Viewed 3086 times
Posted: Fri, 22 Jun 2018, 19:23
by PiMan
Makes me kinda sad to learn that an electric bus project has fallen through. I don't have any use of one of these batteries, but I'm happy others do.
Posted: Fri, 22 Jun 2018, 19:56
PiMan wrote: Fri, 22 Jun 2018, 19:23 Makes me kinda sad to learn that an electric bus project has fallen through. I don't have any use of one of these batteries, but I'm happy others do.
Yeah I was really bummed to hear about that too. Would have much preferred an Australian company to build E-buses than a bunch of storage batteries, but if there is a silver lining, it's that the EV community got to make use of the remaining cells.
Posted: Fri, 22 Jun 2018, 20:55
Should point out that there are still some 11 kWh battery packs available over east:
(Updated 9:48 am WST 24/06/2018)
ACT 0
NSW 0
QLD 0
SA/NT 0
TAS 0
VIC 0
WA 0
WA filled its allocation within about 3 hours!
Posted: Sat, 23 Jun 2018, 06:23
by 4Springs
They are very light for LFP. I can see why they were going to use them in buses.
I could make a 10kWh 'generator'. Plug it into the 240V to charge up, then it provides 240V output. Use it as a range extender for the Brumby (charger on while driving), and as an AC coupled home storage battery. The battery would only weigh 75kg - so perhaps not much more than 100kg with a suitable box, inverter etc.
Will some cells be left over to replace any that fail?
Posted: Sat, 23 Jun 2018, 06:26
by 4Springs
I'm not sure that the specifications are correct for the 220Ah version - they are exactly the same as the 460Ah version except for the weight. Even lists the capacity as 460Ah!
Posted: Sat, 23 Jun 2018, 09:28
4Springs wrote: Sat, 23 Jun 2018, 06:26 I'm not sure that the specifications are correct for the 220Ah version - they are exactly the same as the 460Ah version except for the weight. Even lists the capacity as 460Ah!
That was my typo... Sorry about that.
Posted: Sun, 24 Jun 2018, 06:17
by 4Springs
No, hang on, I'm wrong.
The dimensions are not the same, the 460Ah one is taller - as per the photos above and as per the specs if I read them properly.
Posted: Sun, 24 Jun 2018, 11:01
All the cells have been allocated to each branch - none remain. Thanks to everyone - you will be getting an email with payment and shipping details early next week.
Chris
