$6000 EV
- Real Name: David Rowe
$6000 EV
A big problems with EV conversions is cost. I can't help thinking that if we can get the cost of a basic EV down to say $6k then we might see a big rise in adoption of EVs. It then becomes maybe 2 years fuel costs and looks good for an average commuter, plus many people would buy just for the green angle.
At the moment your choices are a $15-20k conversion of an older car or a $40k modern car (like a Getz) professional conversion. So you have to be pretty keen on EVs and cashed up.
So is a $6k EV possible in Australia? I thought I would start this thread to get some ideas on how to dramatically lower EV conversion costs.
Here are a couple of my ideas:
1/ Have a spec of 40km @ 80% DoD, mainly 60km/hr driving. I am trying to set the spec low to allow for 72V systems. This also reflects my Adelaide bias, I guess the rest of AU living in larger cities with urban freeways might see this as unworkable. Feel free to debate this spec - the idea is to capture as much "low hanging fruit" of the ICE market with the lowest price EV. I feel that EVs can stand on their own today for many common missions we currently use ICE vehicles for.
2/ Volume manufacture of adapter plates and coupler. I imagine we could get 10 made for $200/vehicle if they are already programmed into a NC machine. Maybe keep the clutch to make the transition easy? This might add expense, not sure.
3/ Lead acid is the obvious low cost choice but how about a 72V Lithium pack? BTW I agree that that the long term running costs are lower for Lithium, however what I am trying to hit here is a very low up front capital cost. I figure the key is to get as many people as possible to experience EVs - the key to that is low capital costs.
4/ At a total cost of $6k the donor cars could be a little rougher than if you are spending $20k, so we could save there.
5/ A 6 x 12V battery system could be charged with 6 x $80 12V car chargers, so charger costs < $500. Maybe something similar for Lithiums with some sort of BMS.
6/ Could we build 10 EVs for $60k? I imagine a discount of perhaps 30% for 10 x motors/controllers/batteries etc, especially buying direct from the US.
7/ Really simple battery racks and standardise on one vehicle (or just a few). I know I probably spent twice as long on my EV conversion as I had to.....
I would appreciate all your thoughts & brain-storms.
Thanks,
David
Thanks,
David
$6000 EV
My budget is bit less then that and all new gear My Barina was actually free i sold all the combustion stuff. Chinese controller 9.1"motor 8.5 kW top 45 hp charger-96 volt- around $2.400 batteries $2000 8x100amp-agm. Bigest expence can be our local Engineers for modification aproval and safety compliance plate/// demister $50 vacuum pump $200 cables and connectors $200 incidentals $300 engineering $300 $5500 the lot rest is ones own work. and that is where it can become expensive-- labour cost-- easy double the total cost. If one is not in a hurry it is a good and constructive hobby....
A lot of folks can't understand how we came to have oil shortage here in our country.
~~~Well, there's a very simple answer.
~~~Nobody bothered to check the oil.
~~~We just didn't know we were getting low.
~~~The reason for that is purely geographical.
~~~Our OIL is located in
~~~Bass Strait
~~~East Queensland Shale Fields
~~~Canning Basin
~~~Perth Basin
and
North-West Continental Shelf
Our DIPSTICKS are located
in CANBERRA!
~~~Bass Strait
~~~Canning Basin
~~~Perth Basin
and
in CANBERRA!
- Real Name: Ben Roberts
$6000 EV
6K eh.... I would think if you were making a thousand you might be able to work the costs down to a mark around there. However, the least expensive conversion option is using a DC motor and controller. Series DC motors are mechanically and electrically inefficient compared to AC so in some ways it wouldn't be the best advertisement for EV's in general. The type of speed/range value you've nominated could be done with a 72V pack but not many people are going to be truly happy with a car limited to 60Kmh and 40Km. I'm sure the right niche market could be found especially amongst the capital city commuters so that may not be a big problem.
The main problem is that the hardware is still going to consume almost all of your 6K leeaving little for the job of actually performing the conversion. This is why the Blade costs what it does. Sadly, the market for EV hardware is still small and specialised. In addition to this, no Australian enterprises have stepped up to the plate to offer any locally made equipment. This still mystifies me. With all the engineering resources we have here and a good many electrical equipment manufacturers.....nothing.
The "Perfect Storm" for your idea is:
A local manufacturer of an EV specific motor/controller combo.
Standardise on one model of car to convert (Corolla?)
A BIG battery order from China.
I don't think you'd get down to 6K but you might get close.
- Richo
$6000 EV
drowe67 wrote:So is a $6k EV possible in Australia? I thought I would start this thread to get some ideas on how to dramatically lower EV conversion costs.
Hmmm Interesting.
Surely a smaller DC motor on a light vehicle with low range should be possible.
I might go crunch some numbers
- Richo
$6000 EV
does the $6k include the doner car?
If it does then it would need to be a bucket of rust with 25km range.
$6000 EV
Have you ever finised one EV yet?
If you have then i will listen to you-- If you have not then you are full of hot air and very critical what people say as a discussion and sceptical what people do.... You are not king Solomons progeny.
Oliver's Law of Public Speaking
A closed mouth gathers no feet.
- woody
- Real Name: Anthony Wood
$6000 EV
Richo,
2nd hand cars are cheap if you go for ugly and/or boring and/or unreliable.
cheers,
Woody
PS: Use more smileys ppl. things are getting tense
cheers,
Woody
$6000 EV
Most suitable Cars availabe in queensland for conversiona Are--Holden Barina. Daihatsu Charade-Suzuki swift-city- ford laser gl Ford Festiva-
Mazda bubble 303--- all these on e-bay around 500$ Make offers.. They are not old cars and most for sale are clean and bodies good.. and the motor? It Don't metta--- Most these are round 750 kg Curb weight. ---Plus you can pick any big petrol guzzling car for few dollars
But you will need double AC POWER just like petrol power
- Richo
$6000 EV
$900 Excel
Goombi's the man.
He has already done what David has asked.
Is there a place where we can see your car so others can build one too?
You don't need to listen to me.
My hands are tied until our local govt approves my mods for my eV.
drowe67 wrote: Nice work Goombi - can you post some links for your motor/controller/charger pls?
Goombi's the man.
- Richo
$6000 EV
Goombi will you be releasing Barina kits?
If you build 10 kits would it make it cheaper for other people wanting to drive an eV today?
This might be a good way for AEVA to get people into eV's
AEVA could hold workshops where members/visitors could come in and get hands on building one.
That way conversion cost is down as people who want to build/learn are doing it for free.
Then sell the car.
Good work Goombi
Then sell the car.
Good work Goombi
- Richo
$6000 EV
But that is the point of this thread.
Make an eV for under $6k.
YOU have done it.
So how can we make what you have done into kit form?
The easiest would be if you sold kits.
Do you have links or a blog that others can follow?
My option included a bucket of rust excel with only HALF the range.
So my option doesn't sound so appealing anymore.
YOU have done it.
- Real Name: Craig
$6000 EV
Richo wrote: does the $6k include the doner car?
I saw a 4 door late 80's early 90's BMW E series (E30? was like the one in your avatar 318, 325 that sort of model) for sale for $600 on friday.
So not all cheap cars are rust buckets.
$6000 EV
My search is almost finished.
Ordered Dc-Dc converter from china $258 delivered and its what i needed to the spec.
The heater demister is also solved see-heater-demist chat
Pump and switch new cheap Thomas.Made my own vacuum canister from Iplex PVC pipe.
Motor controller -coupler-fitting and charger all ready.
but i am not--
all costs falling withing the under 6000$ conversion.
From now its up to me to machine the plate and coupling set it up batteries are ready to be picked up 8x100amp agm plus one auxilliery 60amp.. Have the steel and bolts for battery boxes and above the el. motor shelving for all the miriad of wires conduiting and motor waterproofing louver plates.
Cables are ready to cut for batteries and orange conduit to taks the high power cables under the car.
Now its up to me.. move-move.
Ifter i decided to make this BARINA EV in June i give myself 6 week for Barina to be ready for registration.I think it will be 12-15 weeks now
There was some delay in chosing the right parts. and the delivey delays
Very happy with the budget and the final cost will now depend only on Qld Transport Engineer to aprove the EV for registration.
Then i will make my rounds of Local businesses to see if they can make small donation for the sign and advert. My barina will be local car and used in town mainly so it will be beneficial for business houses to support a polution free vehicle.. I will also go to PETROL STATIONS and take donations without adds.. i like this GAMBIT This will be fun.
I will also bombard the gov. and oposition to Support EV converters with 4.000$ min donation towards any EV that will be registered- within 9 month. When my car is ready and registered I will apply for a petition to support private EV manufacturers... When i am ready i will ask all of you to help me with signatures in your areas. Thanks
$6000 EV
Why is the 6k the upper figure. please consider another approach that provides up to $12,000 a car based on a cross subsubsidizing of the car conversion from the savings on house running costs. If you take a subsidised solar energy roof top installation and swap half its battery pack each day into your car and allow the power savings on home generated electricity and funds saved on fuel and car servicing and running costs you can pay off a line of credit loan of $15,000 over 5 years at it low rate interest of around 6%. if oyu travel an average of 50km a day.
After paying for the solar install, you have 11,000 to 12,000 not $6000 to build you car conversion.
Strip out the engine and gearbox and use an inverter and 3 phase controller ac motor coupled direct to an replacement for the free wheeling rear wheels by using a retrofit rear wheel diff to replace the front wheel drive. Put the batteries and tyre in a quick swap over, slide in slide out tray in the front of the car where the empty engine is. Batteries at 40watts.hrs/kg will provide 5KW.Hrs of drive power from 150kg of batteries. The controller and inverter and ac motor should provide a short duration 15KW peak power drawdown for acceleration and the batteries should run the car on flat roads for a draw down of less than 3 KW continuous and require a near zero demand at red lights and on downhill runs. Everything else remains unchanged except the low pressure motor pump needed to drive the vacuum booster on the brake circuit and the power steering pump. Vehicle mass should be around 100 to 140 kg lighter with no engine gearbox and a top speed of 65 kph. I have based the energy average of .09kwHrs/km specific energy usage and a vehicle mass without passengers of 750 kg.
bro
$6000 EV
Ive got a 1967 datsun 1000 - perfect mechanicals inside out
great body factory weight 635kg (with heater 625kg without)
no power steering - dont need it its so light and simple
no air con - cool white duco, good ventilation & 12v face fan
no power assistance yet stops like F1 racer due to disc upgrade
no electric windows so keep my arms from been useless
no radio so I can converse keeping my brain clear
Ridding the ICE running gear will make it even more enjoyable.
how much to make it an EV using Goombis method probably a tad less
but at least I can have a simple A to B car with easy upkeep and
will make others see that fancy is just not always needed
I really like the Trev and the Tango T series - any car that seats two in tandem for the changing world of overcrowded cities and burbs and small driveways just makes total sense but who is going to make it locally and pass all the laws to protect Ford and Holden?
- Richo
$6000 EV
Hey Bro - Sounds good in theory.
But I seriously doubt it could be done as you suggest.
The batteries should be charged at night at the low rate rather than suck off the excess solar power during the day.
Having two packs doesn't really make economic sense either.
A rear end retro-fit kit sounds nasty - extra cost to buy and to certify.
A personal loan is more like 9-10%.
Current interest rates on a secured property is more like 7%.
Getting an an secured loan for an eV conversion would be tricky at best.
Nice thought tho
Nice thought tho
$6000 EV
Goombi wrote: AM Prentice: Sensible atitude-- simpler the better Regards Goombi
Pity Im not as sensible as you Goombi Im still wet behind the ears at 42 yrs old but hopefully in time I can drive my creation certified with an EV smile
Re: $6000 EV
Interest rates are at record lows... inflation has crepted up slightly. Manufacturing cost are down. Tech has improved... what's the new budget conversion cost today?
Re: $6000 EV
For a half decent, 150 km range EV? About $40k.
For a bare bones, DC, good enough? About $20k.
Li-ion batteries haven't gotten cheaper, but they have gotten better. What used to take up a whole boot and then some for 100 km around town now takes up half as much space.
