if its suitable for a Tuarn-pioneered like AC conversion.
The seller doesnt sell internationally so Im going to get a mate
to buy it for me over there and deliver it to me here.
That is if its the right Drive? Its so small!!
Its a Kimatek drive KMP series
KIMATEK
50hp 460VAC
I really need to move on it before it goes though otherwise the
Azure controller is really something if it can run an industrial
motor as its minimal input voltage is 144 volts.
Im considering the Greensavers too but in sp27-12 27ah @ 2hrs.
Anyone know the cutoff voltage? (10.5 for safety?)
How many will I need to get this drive working well?
I know 50 x 12v would be great but 500kg wont do.
I was thinking 37 or 38 of them would that be enough?
Power HP(C.T/V.T): 50HP / 60HP ----(is this true??????)
Input Phase / Voltage(Vac): 3Phase / 380 ~ 500Vac
Rates Input Current: 72A - Output F.L.A.: 72A
Max. Output Torque/Freq: 200% / 0 ~ 800Hz
W 225mm x H 465mm x D 330mm Weight 22KG
