G'day
Has anyone heard of an electric hot rod in Australia? Because they have separate chassis and body would that make them easier to covert/build? Ta.
Electric Hot Rods
- woody
- Real Name: Anthony Wood
Electric Hot Rods
There is a Caterham (Lotus 7 replica?) which was kit built as an EV by one of the Sydney members - does that count?
I think front engine - RWD gives you plenty of access.
The older the donor car, the simpler it is as various complexities weren't invented - CANBus, ECU, A/C, Power Steering, Power Brakes, Reversing Lights, Heater/Demister.
It also seems that Hot Rods have a fast track to rego somehow - not sure how that works - maybe just that certain chassis are a known quantity...
- EV2Go
- Real Name: Paul
Electric Hot Rods
Yes but it's just an idea in my head. For quite some time now I have been slowly gathering information on an early 30's hot rods like a pinched nose for EV use.Kieran wrote: G'day
I wont say conversion because basically the car would be built from scratch as an EV. There are some great early 2 door body styles (my preferences are towards the 3 window styles).
I can very easily see a Kostov duel 11" sitting quite nicely between the chassis rails with a 9" out back.
Because they are basically a kit the wiring is so much simpler than trying to convert an existing vehicle.
