EV Roadster -Pontiac Fiero- Newby
Tareaway
Real Name: Darren West
MSN: drwest0072@hotmail.com
Post by Tareaway »
Hi, looked into EV's sometime ago but due to commitments couldn't go ahead. I have a 86 Pontiac Fiero (small 2 seater-Plastic body)that I wish to convert, the motor and transaxle already removed. It will have a custom body when complete. Im seeking assistance with information and leads regaurding this progect. Setups suggestion would be appreciated. This vehicle will be used for promotion and will not require registration. Any ideas? Thanks
DRW
Maybe tell us what perfomance you want to get out of it or a rough budget you want to work to.
Tareaway
Post by Tareaway »
Looking at a balance between acceleration, cruising and range (lol asking too much?), the vehicle minus running gear will be very light weight. A mild sports setup? prerhaps? range can be sacraficed Acceleration and a reasonable cruising speed would be prefered
DRW
Tareaway
Post by Tareaway »
what information do you require to make some suggestions? I am serious about this project as it will by learning curve for future Ev's. Thankyou
DRW
zeva
Real Name: Ian Hooper
Post by zeva »
Hi Tareaway,
Here's a PDF I put together recently to kick things off:
http://www.zeva.com.au/publications/Sports_Cars.pdf
It'll probably raise more questions than it answers, but maybe a good place to start for considering component selection etc!
Ian Hooper
Tareaway
Post by Tareaway »
Thanks Ian. No relation to a A.F Hooper?
DRW
Mr Camouflage
Real Name: Craig
Post by Mr Camouflage »
Hi Tareaway
Take a look at the ev photo album to see how others have converted their Pontiacs.
http://www.evalbum.com/type/PONT
