Certifying Engineers for ICV
simsfamilyfrance
Real Name: Chris Sims
Post by simsfamilyfrance »
hi there,
I am designing an EV from the ground up.. chassis is similar to a clubman.. 4130 steel, 2 seat, open roadster.. I have been quoted approx $20k for the engineering certification.. by the time all is said and done.. ADRs. chassis tests, doco etc..
Does this sound correct? It is a lot more than I thought it would cost. Does anyone have experience with this process and or can recommend someone with a sharper pencil?
cheers,
Chris
Canberra32
Real Name: Damian butcher
Post by Canberra32 »
God no!!! 5k not 20...
That's exactly the same things we are building and its around 5k depending on how many times you get them around.
Try another engineer
simsfamilyfrance
thank you for the feedback.. I think I have found an engineer in Melbourne who has the experience on the chassis, steering, breaking side. He has quoted numbers around your level, so I think I will engage him to get the initial chassis certification done. He does not have electric drive experience, so we will need to engage with someone who knows AC motors, insulation and controllers down the track.
cheers,
Chris
StudentEV
Real Name: Thomas Paterson
Post by StudentEV »
20k sounds intense.
On this same topic, does anyone know of a good certifying engineer for conversions? In Melbourne...
