i-Miev spare parts
mark_hetho
Real Name: Mark Hetherington
i-Miev spare parts
Post by mark_hetho »
Hi All,
We've been informed the 'Caster' (sic) bushes on the front left lower control arm are looking like they've suffered some wear on our 2010 i-MIEV. Apparently these are only available as part of the whole control arm assembly, which would be about $915 in parts and labour. Apparently no-one sells the bushes by themselves.
So, whilst I'd pay the $915 if it was the only option, I'm wondering if it is possible these match a more commonly available part on another model or make? The other possibility is perhaps in a larger i-MIEV market (Japan or Norway) the bushes are more likely to be available as a replacement part outside the assembly.
I wonder also if anyone else has encountered this?
Regards,
Mark
TooQik
Real Name: Chris
i-Miev spare parts
Post by TooQik »
These guys are the only listing for bushes for an I-Miev that I can find:
http://auto-parts.com.au/mab-da1s-front ... t-arm.html
If you click on the bush picture and view the second diagram it lists the MAB-020 and MAB-021 as the castor bushes but if you search these bushes on their site it does not list them as fitting the I-Miev specifically, but it might be worth contacting them and confirming.
mark_hetho
i-Miev spare parts
I'm not sure how you found that, I have spent some time looking! Thanks!
At least they have images of the part on their site, I can take a look at the part on the car to see if it looks similar. At this price it's a preventative maintenance item more so than a replace when failed.
i-Miev spare parts
Found it on eBay. Says for Volvo but part number is MAB-DA1S as per previous link.
http://www.ebay.com.au/itm/VOLVO-S40-Fr ... 1915515291
i-Miev spare parts
You could also look at Nolathane (religious arguments notwithstanding). Nolathane are easier to fit in this case as they press in from either side - still have to press the old ones out though.
I searched for Volvo S40 Mk2. Hopefully the auto-parts description is correct and it also fits iMiev.
(I don't like Nolathane much even though I'll be using them on the Vogue.)
http://www.nolathane.com.au/do_segue.ph ... F2004-2012
i-Miev spare parts
Post by Adverse Effects »
could you just remake your own??
[tube]https://www.youtube.com/watch?v=d4vPyhl1r7g[/tube]
Last edited by Adverse Effects on Tue, 07 Feb 2017, 05:09, edited 1 time in total.
TooQik
Real Name: Chris
i-Miev spare parts
Post by TooQik »
Here's the rear bush for the front control arm:
http://febest.com.au/REAR_ARM_BUSHING_FRONT_ARM/MAB-066
I overlooked it last night when searching.
i-Miev spare parts
TooQik wrote: Here's the rear bush for the front control arm:
Good find. They have the front one as well (MAB-DA1S) and appear to validate that the front one is the same as that for Volvo S40.
mark_hetho
i-Miev spare parts
Thanks for the great finds everyone!
