Need a "preset" throttle
Gow864
Real Name: (John) Gary
Post by Gow864 »
Does anyone know where I can find a hall effect throttle with high, medium and low settings. I'm building an electric cart, so the variable type throttles are too awkward holding the weight of the cart and dealing with the throttle.
As an alternative. Could momentary switches be used with resistors in line to vary the voltage?
Thanks in advance,
Gow.
you could make a resistor divider between the throttle and the controller, which is selected by switches
Gow864
Post by Gow864 »
Thanks EC sounds a bit beyond me.... Image I was really hoping for an off the shelf solution. I'll keep searching.
If your controller can deal with a resistive throttle, measue the resistance of various throttle positions and rig up buttons with fixed resistors.
Another thing to try is have a volume nob as a throttle mounted away from the handles with a push button on the end of the handle as a go button.
There are also split handle throttles so only 1/3 of the handle is throttle, leaving 2/3 for hanging onto. Also a thumb throttle may suit, leaving a whole handle - emtb.com.au sell those.
Gow864
Post by Gow864 »
Thanks Woody. I like the resistors idea. I'll give it a try.
Your second suggestion is the one I'll use if I can't igure out the resistor thingy....
Gow.
polo-ev
Real Name: Ian Bartie
Post by polo-ev »
I can give you a hand with the resistor dividers if you need.
I did the same thing with my kid's jeep. It does have a variable speed controller but it was too hard to a pot attached to the existing pedal.
I did a small board with 3 resistor dividers on it which gives 3 speeds & stop.
The kids usually only use 2 speeds anyway stop & flat out.
Gow864
Post by Gow864 »
polo-ev. This was for an electric wheel barrow I built. In the end I modified a bicycle thumb throttle and it works great. Still, I would like the option in the future. So, yeah any help would be great.
Thanks,
Gow.
Gow864 wrote: Thanks Woody. I like the resistors idea. I'll give it a try.
Gow.
An off the shelf pot and momentary push button should be all you need as woody says.
Normally there are 3 wires for throttle.
1. +5V
2. Throttle
3. Ground.
The pot (say 5k) would have the first outer terminal connect to the momentary switch then the other side of the switch to +5V.
The middle of the pot to throttle.
The last outer of the pot to ground.
When the button is NOT pressed the output will be zero ie no speed.
When you press the button 5V is applied to the pot and the set speed on the dial is present on the throttle.
You could do something with a rotary switch and preset resistors to set the speed and the momentary switch for go/stop.
Gow864
Post by Gow864 »
Thanks Richo. Of course! what a neat solution.
Gow.
Just remember that without knowing the brand and system of control this is just a guide.
A 5k pot may not suit all controllers as the internal impedance of the controller may vary between manufacturers.
Also some controllers may have a built in detection and know there is an open circuit on the +5V line.
But for nearly all controllers I have seen it should be close anyway to try.
david s
Post by david s »
My Magic Pie Golden Motor has a system like this. You press the "cruise control" button and it holds the current throttle setting you have. It's great. Maybe you could get one and adapt it for your build.
