4wd ev
4wd ev
Richo wrote:
I doubt you could put an electric motor that big between the transfer case and rear drive.
Yeah I did say I doubt it would fit.
IF it fits...
IF it has a through shaft...
^^^See the IF's are BIG Image
All sounds very improbable to me.
I'm still leaning towards full ev with range extender Image
4wd ev
Richo wrote:I'm still leaning towards full ev with range extender
I agree. I can't find any laws prohibiting generator running while towing other than common sense ones like secure cable connection etc.
4wd ev
...Auto cut-out in a crash.
Noise
emissions
Secure mounts
Just the usual junk associated with petrol motors.
Drewdk
Real Name: Drew
4wd ev
Post by Drewdk »
I've been doing some more reading and leading towards full ev with one or two 5kva or similar (depends on cost, compatibility and space)generators under the bonnet(space permitting) and a larger generator mounted into the campertrailer.
Couple of reasons, the campertrailer can't carry a lot of extra weight if I want to keep it legal, so one large generator isn't feasible.
Having one or two under the bonnet will assist with range if I am going beyond my batteries capability and don't have the campertrailer.
What are people's thoughts on this. Thanks
