Need2Charge app
Chuq
Real Name: Charles
Need2Charge app
Post by Chuq »
I'd like to suggest that the EV community in Australia support the Need2Charge app as the preferred way of communicating with drivers of other vehicles at charging stations.
I've seen various methods used:
  • Checking in to Plugshare
  • Putting name/phone number in a note on the dash
  • A hanging tag around the charging cable
Each has various issues. They all necessitate that you remember to check-in or put up the sign every time. People often don't like to check-in to Plugshare every time (many legitimate reasons for this: among other things, if they have a predictable daily or weekly pattern, they don't want to advertise their car is left alone in the same place regularly). The others necessitate putting private contact details on display.
The benefit of Need2Charge is that you only need to do it once, and that's it.
When you sign up it provides you with a custom PDF which includes a badge with a QR code specific to your account. You can put this badge on you car windscreen. Whenever you are parked at a charger, people can either scan the code on their phone, or type in your registration plate on either the Need2Charge app or website, and they can notify you that they are in line for the charger. You get an alert on your app and can have a two way message.
Personally I think as EVs become more mainstream, I think this sort of system will scale better than Plugshare.
Here's a pic of my tag, cut out, laminated, and stuck to my windscreen:
I just leave it there all the time no matter where I am.
The same PDF also has some notes that you can cut out and leave under people's wipers, in case the person isn't using Need2Charge. This is handy for spreading the word about the existence of this app.
Common questions:
Don't you have to enter the country/state as well as the plate number? Just the plate number. If two people in different jurisdictions with the same plate try to use the app, there may be problems! Very unlikely for the time being. The developer is aware and said it can be fixed if it becomes an issue, but the risk of conflict is very low!
Does it cost anything? No, it's free to use. There are no ads either. In the "About" section of the app, the developer has some referral links that he invites people to use in order to support the app. Note that one is a Tesla referral and the others are for UK companies, so not particularly easy for us to support, but hopefully it does the job.
Should I stop checking in to Plugshare? Not if you don't want to! I still do, so I can be contacted via either method. Checking recent check-ins is a still a good way to see if a site is generally reliable and available, or frequently has issues.
Does it work if I have more than one car? Yes, you can link more than one car to your account.
Doesn't this only work if everyone is signed up? Yes, but other systems like Plugshare have that problem too, and for that to work people need to check-in every single time. But if some people start to use Need2Charge, including displaying their tag and putting notes under windscreens, others will see them, and in turn it will encourage some of them to sign up as well. You can still communicate with a registered user even if they don't have a tag visible on their dash by entering their rego plate.
So I'm interested to hear peoples thoughts on this one. I'm happy to write it up as an AEVA website article if people think it's a good idea?
Re: Need2Charge app
Sounds great
getting a bunch of those stickers made up to distribute at EV meetings would be the fastest way to drive adoption
Chuq
Real Name: Charles
Re: Need2Charge app
Post by Chuq »
antiscab wrote: Sat, 31 Oct 2020, 06:14 Sounds great
That's a good idea. However, while the notes [rectangular] that go under windscreen wipers can be done in bulk and handed out, the tag [circular] that goes on your dash has a QR code which is specifically linked to your account. So people are going to have to print their own.
I have a laminator and have bought a pack of A6 size laminating pouches. However the smallest pack was 50. The other 49 are just going to sit there collecting dust, so perhaps I could run a tag laminating session at my next local meeting? :P
adam lippiatt
Real Name: Adam Lippiatt
Re: Need2Charge app
Post by adam lippiatt »
This is a great idea. I saw a recent piece written by Bryce Gaton which mentioned the etiquette of charging beyond 80% at a public charger (bad etiquette).
