tractor conversion
pirpy
Real Name: Borut Lesjak
Re: tractor conversion
Post by pirpy »
first test of mechanic...
https://youtu.be/t73-DLDpyjU
Renault ZOE R240 upgraded to 41kWh
scooter govecs GO1.2 converted to lithium
Solar installation 11 kWp
20 cows
Nice.
Just need to add a bigger battery pack now?
pirpy
Post by pirpy »
32 V test, still waiting for programming console for zapi :(
https://www.youtube.com/watch?v=fGhHhnv ... e=youtu.be
20 cows
pirpy
Post by pirpy »
Zapi in pump mode, no regen, I need reversing and breaking contactors for regen.
Still 32 V
https://youtu.be/8LywRt-vLU8
20 cows
Post by 4Springs »
pirpy wrote: Mon, 10 Aug 2020, 01:59 Zapi in pump mode, no regen, I need reversing and breaking contactors for regen.
Still 32 V
Ah, that looks better. Nice demonstration of going quite slow.
I just noticed your signature and I'm impressed. I only have 2 cows!
It really picks up nicely when you put your foot down too.
The next video from YouTube had the tractor with its engine noisily idling away, it'll be much nicer to work around it once the conversion is finished. It makes me wonder why we don't have more commercial electric farm equipment already (but that can be said about most EV markets, they all have their hurdles I guess)
Post by 4Springs »
brendon_m wrote: Mon, 10 Aug 2020, 06:20 It really picks up nicely when you put your foot down too.
Two major hurdles I can see from my farming experience.
First is run time. 'Proper' farms go through periods of time where they are running their equipment 24/7 to get things done between weather events. Stopping to refuel is annoying, stopping for recharging would be a deal-breaker.
The other is that farming often happens a long way from infrastructure. Even in Tasmania we were often working 30 km from the nearest house, and 30 km is a long way to drive in a tractor. You can take a large tank of diesel and sit it in the paddock for all the tractors and trucks to refuel from. Then get a refuelling tanker to fill it up every few days as required. Nothing like that exists for electric.
The conversion being done here is ideal. This type of tractor is used as a general dogsbody around the farm. You hop on, do a 5 minute job, then put it away. This might happen several times during the day, and noise is a big factor. Then it will occasionally be used for a small slashing job, which might take 3 hours.
Agreed that for big farms EVs aren't ideal, but for hobby farms?
Electric forklifts are a thing and they work very well in the right use case, it's not hard for manufacturers to transfer the technology across.
That being said, electric forklifts are out there but 99% of workshops/farms/industrial settings etc that only use the equipment for 5 min stints and normally have access to good power use petrol/gas forklifts. Too scared of the unknown and too many horror stories of expensive batteries /repairs I guess
brunohill
Real Name: Phil
Post by brunohill »
If used inside sheds etc. there is also no Carbon Monoxide problem with an electric version.
pirpy
Post by pirpy »
First real job
https://youtu.be/SoVb-xVVOFM
Regen is a must, I'm still waiting for relays for that.
20 cows
pirpy
Post by pirpy »
Hello
I installed a regen and reversing contactor on my tractor, and now i need to adjust brush timing to near zero, what is efficiency gain with advanced timing vs neutral?
The voltage and rpm is low but the amps are high.
20 cows
advanced timing helps when running higher voltage at higher rpm (at the expense of performance at lower voltage and lower rpm)
I would suggest do it, and see how it behaves
pirpy
Post by pirpy »
I have a small problem, I need to dismantle the tractor to do this :(
there isn't much clearance.
20 cows
