I've got my Kona
Hyundai and Kia Interest Group
Re: I've got my Kona
photomac wrote: Sat, 07 Sep 2019, 12:52 Day 3 drove to Kalbarri. ...
Is that a Juice Booster 2 EVSE (not visible in the photo) allowing you to charge from that random looking GPO (15 A?) on a tin box you happened to find in the outback? :)
They seem pretty handy, though at nearly 10% of what I paid for my second hand EV, it's hard to justify at present. It makes more sense with EVs like the Kona that have a reasonably powerful on-board charger.
[ Edit: added photo since the original is on the previous page. ]
https://www.evolutionaustralia.com.au/p ... up-to-22kw
‘Tis a Giger with 32 amp 3p socket. Although Hyundai evs can only pull 7.2kw ac single phase.
2020 Model 3 SR+ FSD - Delivered Fri 17 Jan ‘20 - k kms 82
doggy
Real Name: David Kerr
Post by doggy »
For you Kona aficionados:
1. Can you get a factory tow bar? Or indeed any tow bar? With electrics? Approx price?
2. Can you get roof bars? As it seems the same as other non-EV Konas, I assume the answer is yes?
Regds,
Dave
Renault Zoe ZE40, 2017
Peter C in Canberra
Real Name: Peter Campbell
Post by Peter C in Canberra »
doggy wrote: Sun, 08 Sep 2019, 09:02 For you Kona aficionados:
Regds,
Dave
See: https://thedriven.io/2019/06/10/towing- ... t-be-done/ and discussion from people insisting the sky will fall in if you do and others who quote the legislation to show that it won't.
Apparently the aftermarket tow bar fits better, is $100 cheaper than the Hyundai one, and does not require a cut out from the bumper.
Hyundai offered me two options for official Hyundai roof racks, same price, just different styles, when I ordered my Kona Electric.
doggy
Post by doggy »
Hi Peter,
Thanks for the useful info.
Regds,
Dave
photomac
Real Name: Matthew Clifton
Post by photomac »
It is a Giger from EVolution, a Juice competitor. I chose it as I have had positive and efficient experience with the team at EVolution. It is more compact too but doesn’t come with the various adapters that the Juice-Booster 2 comes with.
It is a 3P32A socket. Next to visitors centre in Kalbarri. They have made it available for free. But, as always, ask before using. This also makes the council aware of the need.
Reason: Edited by admin to fix quote bbcode
Yes,   we can.   Image
Kangavue
Post by Kangavue »
g4qber wrote: Fri, 24 May 2019, 11:46 the Tesla Part Number (TPN) needs to be
00-x
01-x
02-x
03-x
are locked into Teslas
Where abouts on the station do you see these numbers?
On the label where the red reset button is
(P)TPN: 1050071-02-J
In this pic.
Trillion Trees
LOT 2 Stirling Crescent (Corner Amherst Road), Hazelmere WA 6055, Australia
https://www.plugshare.com/location/186046
Kangavue
Post by Kangavue »
g4qber wrote: Wed, 11 Sep 2019, 05:13 20140875-D660-4305-9E57-7787E5F79918.png
In this pic.
Trillion Trees
Great. Thanks, very helpful.
Peter C in Canberra
Kangavue wrote: Wed, 11 Sep 2019, 05:18
In this pic.
Trillion Trees
I am not sure this is correct. My car, a Holden Volt, not a Tesla, is, right now, as I write, successfully charging on a Tesla destination charger with that exact same part number 105007-02-J, via a type 2 to type 1 adapter. What was explained to me is that there are internal dip switches that can be set at the time of installation to 'legacy' mode, which works for all vehicles or 'Tesla only'. I have tried about 8 different Tesla destination chargers with my Holden Volt and have yet to find one that doesn't work.
Kangavue
Post by Kangavue »
Peter C in Canberra wrote: Wed, 11 Sep 2019, 14:07
In this pic.
Trillion Trees
Very interesting. I suppose it is best not to drive past without an attempt at them all!
Peter C in Canberra
Kangavue wrote: Wed, 11 Sep 2019, 14:20 Very interesting. I suppose it is best not to drive past without an attempt at them all!
If you see on PlugShare that non-Teslas have successfully charged, you can be pretty sure it will work with a Hyundai.
JD Solar and EV
Real Name: Jon
Post by JD Solar and EV »
Wow, great to see a forum area with actual posts and to see all the Kona owners!
For those newbies, I plan to do an in depth review of the Kona that covers a lot of items that wouldn't normally be covered by CarSales or the likes.
I actually haven't seen a bad review on the Kona yet so I'm not going to waste time retelling the same thing everyone else has done but rather get into some of the nitty-gritty.
There is quite a lot of things you learn over time with this EV so I thought it might be a good idea to build everyone's knowledge up a bit earlier.
Keep and eye out for that...
Current AEVA QLD Chairman
Check out my EV videos at JD Solar and EV YouTube Channel
https://www.youtube.com/channel/UCNMxXc ... bUTfpHU5LQ
Bryce
Real Name: Bryce Gaton
Post by Bryce »
Hi there-on that topic: have submitted a 3 month owner's review of the Kona electric for the next Renew magazine. Should be out next month.
Bryce
Satyros
Post by Satyros »
Hey, first post here :)
I got my Kona Electric (highlander) last Friday - and loving it. I haven't done those long distance runs yet, but coming from the 2003 ICE's.. it's a huge step. Learning charge stations, cables, and all.
Just thought I'd wave my hand to say I've finally made the switch!
Oh, to JD, if you're in the SE of Melbourne, I'm happy to drive past and let you have a look at it - instead of just watching youtube reviews ;)
Bryce
Post by Bryce »
Welcome! Enjoy the EV Grin as it develops. 😆 (Due to no more tailpipe pollution, the ability to wean off fossil fuels, and the stunning ride that all EVs give you. 😆😆😆 )
Bryce
EVdownUnder
Real Name: Patrick Ulrich
Post by EVdownUnder »
Welcome Satyros !
I'm new to it all as well. Got my Kona Highlander only a month ago but have clocked 4000km already due to my job (Field service engineer travelling all over Victoria). I'm sure that like most of us you have followed and learned the Kona on YouTube, but if you have any questions, this forum is fantastic, and if you want a face to face one day, I'm in Upwey. You might spot my Blue Kona on the road or at the closest charger to me, the Knox City Council ChargeFox one. Not a great charger as it allows for 7.6kW but as soon as another car plugs in I go down to 2.5kW. No idea why. It is the only charger I have tried that does this. Frustrating. Apart from that, the Kona is one of (if not) the best value/performance/range for money EV in Oz, and I have data to prove it ;)
Enjoy and see you on the road some day.
Patrick
2019 Ceramic blue Hyundai Kona Highlander - 124Wh/km from new
2014 Dark blue G-edition Nissan Leaf - Bought in Jan 2021 with 45'000km
darrenB
tow bar with the Kona
Post by darrenB »
Hi
thanks for great info! Kona EV certainly a fantasitic car, just waiting for fast recharge stations to be installed in Tassie so that i can make the distance on trips at night, in the cold when the demist function and reduced efficiency of the battery chews away at my range!
my question relates to towing ....has anyone got more information on which aftermarket kona tow bar will fit???........hyundai had agreed to install the kona ICE towbar to my Kona EV (with a clause it wasn't for towing but for my bike rack) but when they went to do the job they said it was 'half a bolt space out due to the beefed up suspension of the EV'.
thanks for sharing!
Peter C in Canberra wrote: Tue, 10 Sep 2019, 07:27
Regds,
Dave
Kangavue
I've got my Kona
Post by Kangavue »
There's now another ceramic blue Kona on the roads. Picked mine up from Lakeside Hyundai, Caroline Springs yesterday, and have hardly left the cockpit, working out instrument panel and 8" screen. What a delight. :P
Still experiencing a little range anxiety until my first, regular 270 and 351 km rural freeway journeys have been initially overcome. :?
I need to get over the ranges and into headwinds, and arrive, before I am fully relaxed.
EVdownUnder
Kangavue wrote: Fri, 11 Oct 2019, 16:04 Still experiencing a little range anxiety until my first, regular 270 and 351 km rural freeway journeys have been initially overcome. :?
Range Anxiety :roll: I laugh in the face of Range Anxiety :lol:
Disclamer: I am a fanatic. Hardly ever use climate control (I'd rather wear a beanie than loose range) and I drive like a grandma.
At least my grandma. Don't want to offend any racing grandmas out there...
Re: tow bar with the Kona
darrenB wrote: Fri, 11 Oct 2019, 08:51
That sounds like the bolt space just needs to be drilled out. maybe to a bolt twice the size for good measure?
Kangavue
Post by Kangavue »
That’s sensational. Don’t think my other half would put up with that for long, or I have the patience. But very impressive figures indeed!
[ Edited Coulomb: first "\quote" - > "quote"]
Mrburns
Real Name: Tom
Post by Mrburns »
Pffttt range anxiety is a made up fear bought to you by oil companies brainwashing everyone for years.
All one needs to do is sit down and look at what you actually do with your car, not hard to plan a trip if needed.
EVdownUnder
559km... I'm head over heels :lol:
On a serious note, you have managed the match the NEDC figures. That is crazy good.
Patrick
EVdownUnder
Sorry, off topic.
I was looking for a good place to have sushi yesterday... Found it !
I asked why Sushi Kona but the workers had no idea. A Japanese Google search returned a not very romantic definition of: flour, powder or dust.
Dust is the only one that makes sense as I sometime leave people in mine ;)
