Time to resurrect this thread of toil.
Francess' car has been in my shed while I wait for new cells to arrive. The LG cells I ordered back in June never arrived, and the vendor claims they were destroyed in customs. When asked why, they said they didn't like the brand name on them (?) but assured me they could find some more. They claimed to have found some more, but insisted they woul dneed to remove the logo so that they wouldn't be destroyed in customs again. My interpretation was - "We took your money but can't find the cells you wanted, so we found some who-flung-dung knock-offs with nothing written on them and we hope you will take them and shut up".
So I have asked for my money back. And went back to my usual cell supplier who has never let me down. I have decided to get 2300 Panasonic NCR19650BD cells and build a 24 kWh pack with cylindrical cells
https://evwest.com/support/panasonic-nc ... asheet.pdf
This is a mountain of work, but there are two upsides. The cells are 100% legit and not knock-offs. I've bought them before and they deliver; they will do a peak of 10 A, but I would generally consider them to be a 1C cell. Secondly, they mean I can fit the original 24 kWh capacity in the under-floor battery space with no need to run cables up into the boot. The overall weight will be slightly less than that of the original battery, and it's all in front of the rear axles.
I'll build the battery as four modules - each in a 24s23p configuration. They will be held together with a pair of polycarbonate capture plates use busplates much like a Tela Model S module, but I doubt I can get them wirebonded easily.
- cylindrical template colour.jpg (1.1 MiB) Viewed 1827 times
- cylindrical pack 3d.jpg (371.98 KiB) Viewed 1827 times
At least spotwelds work. The busplates will be made from laser cut aluminium which is then nickel plated. This means a small nickel tab can be spotwelded to the cell end and to the busplate. If the spotwelds don't stick to the nickel plated ally, they can always be soldered.
- robot drool.jpg (497.83 KiB) Viewed 1827 times
When all is said and done, the modules will be dammed up and fully potted with epoxy encapsulant. Sure, this adds weight, but I want a robust, waterproof battery.
- cylindrical pack dimensions.jpg (774.77 KiB) Viewed 1827 times
The Zeva BMS modules will fit on the back side where the fly-wires will lead around. I'll sit one on top of another on either side of the 100 mm SHS beam in the battery pack. Fix them down with a pair of clamps, and we're good to go. A massive job, but hopefully worth it.
