Fonzarelli X1 - 13 kW motor!
- jonescg
- Real Name: Chris Jones
Apparently it's got a 13 kW hub motor, top speed of 100 km/h and a range of 150 km.
They also have their regular Fonz scooters which run a 72 volt Li-ion battery and a ~4 kW hub motor.
- mikedufty
- Real Name: Michael Dufty
Re: Fonzarelli X1 - 13 kW motor!
That sounds a bit more like 125cc power than their current bike. Probably good for freeway commuting in the morning grid lock but still a bit short when there is no traffic.
- Richo
- Real Name: Richard
Sounds pretty good.
Most of the generic brand hub motors are sub 5kW.
There are no regs on power for an electric scooter it's only an imposed speed limit.
So unless it's limited to 60kph (depending on state) it can't be classed as a scooter.
So it would be registered as a motorbike and you would need a motorbike license to ride it.
10 years later than a Vectrix.
I guess something had to fill the void.
- Richo
Matt might have better info but the Vectrix had a similar top speed but had a peak of 20kW (50% more power).
I'd be surprised if the battery weight had that much difference.
- jonescg
More likely battery power, or the lack of it, from the original Vectrix pack.
Yes, this would be registered as a motorcycle, but only an RE class (LAMS approved).
- mikedufty
The 60kph limit is for mopeds. Scooters can be any power or speed, but are licensed the same as motorbikes. Aprillia make an 850cc one.
I beliive the current Fonzarelli 125 is over the speed limit and requires a license already.
- Real Name: Matthew Lacey
I wonder what capacity the battery is
I'm always leary when manufacturers quote range, more so on bikes.
The range at 40kmh is irrelevant, its the one at 100kmh that matters
having said that, now that we're able to fit 16kwh in a bike, even 200km range is possible
2017 Renault zoe
2007 vectrix - 145'000km
2017 Renault zoe
- mikedufty
My ICE bike only has a range of 200. It does recharge quickly though.
- reecho
- Real Name: Richard Baird
And it's $10k plus on roads.....
Yeah....nah...
Yeah....nah...
- Real Name: Matthew Allen
I was at Close Motorcycles yesterday getting my rego check done and Fonzarelli have moved in next door. So I asked about their new scoot and they said it was 2-3 weeks out. I'll try and check back when they have it in stock. I wouldn't mind taking it for a test ride. Maybe I can take some photos and share them here.
I want to support them because I believe in the end goal of getting away from fossil fuels but I really hope they can keep the price under control.
- carnut1100
- Real Name: Greg Milligan
Took the two slower Fonzarellis for a ride today...
8.5 kW hub motors.
Moped model is limited to 55kmh and is pretty gutless.
The unrestricted one goes alright but maxes out at 80.
Good fun, although it doesn’t handle all that well.
8.5 kW hub motors.
- Real Name: Terry Covill
What would a Vectrix go like with a 16kWh lithium battery pack? Range?antiscab wrote: ↑Sat, 09 Dec 2017, 17:44I wonder what capacity the battery is
Around 200km at 100kmh
There's a fellow who actually did that, by putting in 3 x Tesla 5.5kwh modules in.
2017 Renault zoe
2017 Renault zoe
Interesting, not sure I could get away with another project just at the moment but just maybe .......
