Quant 48VOLT
Quant 48VOLT
Post by Richo » Tue, 21 Feb 2017, 21:07
Well I don't know how legit this is but the specs and innovation are impressive.
The Quant 48V only uses 48V fuel cells so no dangerous voltages.
4 x 45-Phase motors 140kW each for 560kW.
Although it would require refueling infrastructure it definitely could be a contender against BEV's.
http://newatlas.com/nanoflowcell-quant-48volt/47973/
Quant 48VOLT
Post by Johny » Tue, 21 Feb 2017, 21:15
Hmmm. 480kW (just assuming a bit more) at 48V - that's 10,000 Amps.
Yeah - that's OK. Silicon losses - I guess MOSFETS.
Dunno - I don't believe it.
Either false or some trick of the marketing dept. Maybe all the flow cells are in series and the rest is internal miscommunication.
Rusdy
Real Name: Rusdy
Quant 48VOLT
Post by Rusdy » Wed, 22 Feb 2017, 17:26
Johny wrote: ...and the rest is internal miscommunication.
Sounds like it. Maybe, just maybe, the journalist's source mistakenly sent him the 48V standard instead? 48V Standards
Quant 48VOLT
Post by Richo » Wed, 22 Feb 2017, 20:46
Well from the motor point of view it's plausible.
140kW with 45 phases is 65A per phase.
So a 3mm ali rod per phase Image
Yeah the 10kA from the fuel cells is questionable.
Quant 48VOLT
Post by Richo » Wed, 22 Feb 2017, 20:56
I still think 48V is a bit low.
I was playing with a 60V pack this week and purposely touched each terminal to see at what point it was "uncomfortable".
Even at 60V it was not an issue.
I guess if I was pissing out blood from my finger while doused in petrol I'd think twice about touching 60V.
Still even if they did bump the Quant up to 96V that's still 5,000A+ Image
aldorone
Real Name: Alfonso D.
Quant 48VOLT
Post by aldorone » Wed, 17 May 2017, 02:30
Interesting. The range and speed are a bit amazing.
