E rider scooter batteries?
jordanmills
Real Name: Jordan
Post by jordanmills » Sat, 16 Jul 2016, 00:23
Ive recently aquired an erider scooter i believe that needs new batteries. Does anyone have any recommendations on a replacement?. Ill be running a QS273 hub motor with a 72v 80amp controller. Was thinking lipo as the cheapest route but are there any viable lithium options (without costing a bomb).
Cheers Jordan
Post by antiscab » Sat, 16 Jul 2016, 12:59
Does your scooter have the blue chl 50ah cells, or the yellow 60ah thunder sky cells?
Leaf modules would probably be the cheapest, but would involve a bms change. I would recommend something programmable such as the zeva offering.
From memory the erider scooters were fairly light on for instrumentation. Scaled voltage guage instead of an ah counter for a fuel guage, for instance. Have you had a chance to do a capacity test?
The erider batteries are under sized imo.
2011 Blade Electron mk6
2007 vectrix - 145'000km
1998 Prius - needs batt
jordanmills
Real Name: Jordan
Post by jordanmills » Sat, 16 Jul 2016, 13:07
I bought it without any batteries so unsure as to what were the originals. Will pick up the scooter next week. Just trying to plan everything out
Post by antiscab » Sat, 16 Jul 2016, 13:21
jordanmills wrote: I bought it without any batteries so unsure as to what were the originals.
Ah no batteries makes it interesting.
Calb 60ah cells should fit, as may the Calb 70ah cells.
The original bms is not of the greatest quality, assuming it still has one.
The motorcontrollers tend to have a high failure rate, it would be worthwhile to test it, just to make sure it's worthwhile.
I do know of another erider for sale here in Perth. This one has a sevcon controller installed. It may be cheaper. Buying that scooter and keeping yours for parts than buying new parts for yours.
jordanmills
Real Name: Jordan
Post by jordanmills » Mon, 18 Jul 2016, 13:21
Cheers, i've got one local here for $700. Controller has been swapped out for an ebike version (72v 80amp), so a much simpler setup paired with the QS273. I'll have a look at these cells.
Post by antiscab » Mon, 18 Jul 2016, 18:25
If that other scooter has good batteries, it's a good buy
swapping *to* a 72v 80A controller is an odd swap, I wonder why they did that
Running on the original controller is very slow going. Part of the reason the failure rate is so high is because the small controller is running flat out all the time
If you ever find yourself in need to replace a prematurely dead motor controller, go bigger. Not just for better performance, but a larger controller is less stressed and less likely to fail
On Theo's bike I put in a kelly 72v 400A controller - you can current limit in software, but the difference was like night and day
jordanmills
Real Name: Jordan
Post by jordanmills » Mon, 18 Jul 2016, 18:30
Thanks, i do have the option of a Kelly controller or might go sabvoton (150amp). Both similarly priced i believe. Just need to sort the battery dilemma first
jordanmills
Real Name: Jordan
Post by jordanmills » Wed, 20 Jul 2016, 17:55
Well ended up buying 9 6s 12000ah Graphene lipos. Were on special and too hard to pass up. Will run in a 18s3p configuration for 75v 36ah pack. Will bulk charge majority of the time and balance if needed. Will make a build thread.
jordanmills
Real Name: Jordan
Post by jordanmills » Sun, 24 Jul 2016, 21:57
Can anyone help identify what these wires/ plugs are for??.
Not getting any power up to the ignition
jateureka
Real Name: Jenny Theiss
Post by jateureka » Fri, 29 Jul 2016, 17:24
Would help to know what controller you are using.
E-Bikes: FreeGo; eLation V2; Bafang 8FUN; MAC; Ezee
E-Motorcycles: ZEV 7100 LR; Zero S 2011
E-Mower: Ego push mower & line trimmer
E-Power: 3.3kW solar panels and Xantrex inveter
jordanmills
Real Name: Jordan
Post by jordanmills » Fri, 29 Jul 2016, 17:52
Wires are off the original harness and not the controller (Yuyanking brand). I've take it up to an Auto Elec to get sorted
pahealey
Real Name: Philip Healey
Post by pahealey » Sun, 31 Jul 2016, 14:08
Hi Jordan,
I recently bought an Erider without batteries or controller as well. I have been researching batteries as well. I am very keen to get the CALB LiFePO4 72ah batteries which appear to be the highest capacity I can squeeze into the battery box. I am trying to get them directly from china from evlithium.com cost about $145 each delivered. They are about $200 each from ev-power.com.au with postage to east coast. A cheaper way to do it would be getting Winston 40ah batteries from EVwork.com.au or www.thebackshed.com/basiclynatural for $72 each. I need 24 cells. Where did you find your lipos?
I managed to power up the 12V system yesterday. Under the lockable compartment in front of the seat in a conector with black, green and yellow wire. POsitive 12V to black, negative to green will power up the normal electrics. The bike has only done 1900km!.
My bike still has the connector for a Sevcon controller so I have downloaded the manual for that controller and was planning to then figure out the wiring for my Sabvoton controller. I bought the Sabvoton on Alibaba for $350 delivered. You can get Size 4 Sevcon on Ebay for US$400 but Sevcon wouldn't give me an access file for their software and the IXXAT conector you need for them is $300.
I,m interested in your thoughts
Phil
Post by antiscab » Sun, 31 Jul 2016, 17:12
I've been down this path before - be aware that the fixed fees for a sea importation add up to around $1000
unless you are buying *lots* of cells at the same time, it's rarely worth doing an individual importation
out of curiosity, have you considered leaf modules?
you would only need 9 or 10 modules (each module is $190 and 60Ah 8.4v)
you're going to need a new BMS either way
Does your e-rider have the TC Charger installed?
pahealey
Post by pahealey » Sun, 31 Jul 2016, 18:26
Where can you buy Nissan modules in Australia? AQuick search hasn't had any results. I have a TC charger.
Evlithium quoted US$390 door to door but it does seem to cheap as even Get would be $300. I don't want them dumped at the dock.
Phil
2010 Gen 3 Prius
2 x E-bike
2014 Zero DS
Post by jonescg » Sun, 31 Jul 2016, 18:37
I second Matt's comments - just buy them from EV-Power or EV-Works, depending on what you're after. Going direct to China is simply not worth the hassle. At least if you buy them from an Australian business, everyone is covered by the Australian Consumer Protection legislation.
Post by coulomb » Sun, 31 Jul 2016, 18:47
pahealey wrote: Where can you buy Nissan modules in Australia?
Graeme from Suzi Auto and ozdiyelectricvehicles has imported these in the past. The trouble is that they come from wrecks, so supply is not guaranteed. It also depends on when he's imported a batch, and how many are left over.
See for example this post:
viewtopic.php?title=leaf-cells&keywords ... 976#p60239
jordanmills
Real Name: Jordan
Post by jordanmills » Sun, 31 Jul 2016, 23:27
Yes i did the maths on the battery setup. Using leafs was going to be around $2500, with BMS included. Using the CALB cells was slightly more i think. I picked up the Lipo's from Hobbyking for $80 a pop, Bought 9 for $800. 75v 36ah should get me moving nicely.
Had the auto Elec guys sort out my wiring for $150, Will pick it up tomorrow. Had a dud DC DC converter so a replacement was ordered. Should be good to go.
Only issue i have is there is no ignition shutoff from the battery...so once key is out, full throttle can still be applied which isnt good lol. Will tap into the controllers ignition wire and feed off the bikes ignition barrell (2 red wire, 1 yellow). Other alternative is to disconnect batteries under the seat using Andersons, which can be locked
pahealey
Post by pahealey » Mon, 01 Aug 2016, 02:53
Has anyone tried to buy Nissan leaf Batteries new from Nissan? I believe they are about $8500 for 24kwh (when sold as replacement) which is very reasonable.
2010 Gen 3 Prius
2 x E-bike
2014 Zero DS
jateureka
Post by jateureka » Mon, 01 Aug 2016, 11:37
There should have been an isolation switch / circuit breaker under the seat.
There is a very large thread on the V is for Voltage forum on the e-rider and the guy strips it down and repalces a controller, etc with lots of pics. May be helpful to you.
http://visforvoltage.org/forum/11326-er ... r-xm5000li
Are you using a BMS for your LiPo?
jordanmills
Real Name: Jordan
Post by jordanmills » Mon, 01 Aug 2016, 12:46
jateureka wrote: There should have been an isolation switch / circuit breaker under the seat.
Been through that thread, and even emailed another guy for pics. Maybe i should post them up here as a resource.
There is indeed a 100amp circuit breaker (AC though) under the seat. I may end up just using this for simplicity. No BMS for Lipo, never had an issue using them on my bikes. Will balance charge every few weeks and just use 3 server power supplies to bulk charge at 15amp
pahealey
Post by pahealey » Tue, 02 Aug 2016, 13:37
I have been looking into Lipo option suggested by Jordan. 6S lipo cells are 22.2V or 25.2V at full charge. 3 in series gives 66.6V nominal voltage or 75.6V at full charge. 4 in series is 88.8V Nominal and 100.8V at full charge. The maximum normal voltage with 24 LiFePO4 cells would be 87.6V. Would 4 of the Lipos in series be too much?. Also I would like to bulk charge with my TC charger which has max Voltage of 87.6V. As you can tell I am rather new to battery tech and do appreciate your input.
2010 Gen 3 Prius
2 x E-bike
2014 Zero DS
jordanmills
Real Name: Jordan
Post by jordanmills » Tue, 02 Aug 2016, 14:00
pahealey wrote: I have been looking into Lipo option suggested by Jordan. 6S lipo cells are 22.2V or 25.2V at full charge. 3 in series gives 66.6V nominal voltage or 75.6V at full charge. 4 in series is 88.8V Nominal and 100.8V at full charge. The maximum normal voltage with 24 LiFePO4 cells would be 87.6V. Would 4 of the Lipos in series be too much?. Also I would like to bulk charge with my TC charger which has max Voltage of 87.6V. As you can tell I am rather new to battery tech and do appreciate your input.
You wont be able to use your charger unless you can dial the voltage down. Most of the bulk chargers (no balance ports) you can adjust the output of the charger. What i plan to do is get 3 power supplies and series them to get my output of 75v nominal. If you are planning to go with lipo you will need a balance charger (RC). These can be pricey. Also you need to work out the amps you are pulling to match the C rate of the batteries. If talking lipo's go with 1/4 of the stated C rate stated.
PM Me if you have any problems
pahealey
Post by pahealey » Wed, 03 Aug 2016, 13:31
Would getting rego be a problem with Lipo cells ? Also the thought of individually balance charging 9 or 12 or 15 cells every 2-3 weeks sounds onerous. However, your option is far and away the cheapest way to get a 36 or 48 or 60ah pack into the bike. I hope those Hobbyking cells stay on sale while I ponder.
2010 Gen 3 Prius
2 x E-bike
2014 Zero DS
jordanmills
Real Name: Jordan
Post by jordanmills » Wed, 03 Aug 2016, 14:00
pahealey wrote: Would getting rego be a problem with Lipo cells ? Also the thought of individually balance charging 9 or 12 or 15 cells every 2-3 weeks sounds onerous. However, your option is far and away the cheapest way to get a 36 or 48 or 60ah pack into the bike. I hope those Hobbyking cells stay on sale while I ponder.
I dont know what the rules are for other states, but any "electric motorcycle/ scooter" has free rego in Victoria. Using lipo or any other chemistry shouldn't have nay impact. Sadly that's the price you pay for lipo, when balancing. You can buy a $300 charger or multiple and charge in no time. (15-20 amps), using a parallel charging board you can cycle through them in a few hours. Some people have gone 30 cycles without balancing with no issues. Just keep an eye on the cells and weed out any duds
pahealey
Post by pahealey » Sun, 14 Aug 2016, 20:20
I have decided to go with Nissan leaf modules with Graeme at Suzi auto. I have ordered 10 modules and should be able to charge these with my TC charger. Due to the delay til these come, probably 2-3 months, I have also ordered 3 12Ah lipos from hobby king to get the bike going. After factoring in the cost of chargers for the lipos as well as the hassle they were less attractive. I will use the 3 lipos for a battery pack for my e-bike after getting the nissan modules. Still have to figure out the wiring though.
2010 Gen 3 Prius
2 x E-bike
2014 Zero DS
