- Real Name: Joseph
plugged in & out 3x
plugged in & out 3x
- Real Name: Joseph
had to reset @ meter box.
- Real Name: Joseph
2011 i-MiEV - 168 k kms
- Real Name: Joseph
- Real Name: Joseph
- Real Name: Joseph
2017 Renault zoe
2007 vectrix - 145'000km
2017 Renault zoe
- Real Name: Joseph
http://gm-volt.com/forum/showthread.php ... ?_k=r4yss4
Fixed in 2016 volt
Fixed in 2016 volt
- Real Name: Peter Campbell
- Real Name: Joseph
Hi peter C
Any solution yet?
- Real Name: Rob Hills
Hi Peter,
HTH,
HTH,
Jul 2014 - Dec 2018
Total Petrol: 622.0L
ODO: 44964
Av Consumption: 1.38 L/100km
Jul 2014 - Dec 2018
ODO: 44964
- Real Name: Joseph
Solution
Solution
I use the Volt EVSE with my Mitsubishi iMiEV and it has never tripped. At home I use the iMIEV EVSE for both cars and the Volt trips just often enough to be annoying but the iMiEV never trips. My conclusion, like the one earlier in the thread, is that it is the Volt itself, not the Volt EVSE that is causing RCDs to trip itermittently.rhills wrote: ↑Sat, 12 May 2018, 14:12Hi Peter,
HTH,
Hi Peter,
My experience is obviously quite different from yours as we don't own a Volt. Maybe our EVSE (which I purchased from @g4qber with full disclosure about the issues he'd experienced with it) is faulty and it's a different problem from yours...Peter C in Canberra wrote: ↑Sun, 13 May 2018, 14:26My conclusion, like the one earlier in the thread, is that it is the Volt itself, not the Volt EVSE that is causing RCDs to trip itermittently.
Jul 2014 - Dec 2018
ODO: 44964
Jul 2014 - Dec 2018
ODO: 44964
I got a 2m cord from Jaycar with an RCD device in-line and experimented today. Sometimes it tripped, sometimes it didn't but the house RCD always tripped when the cord tripped. Sadly, the cord tripping did not save a trip to the meter box to reset the RCD there.Peter C in Canberra wrote: ↑Sat, 12 May 2018, 11:17Any solution yet? ... I am wondering if it is worth getting a portable in-line RCD cord? My thought is to have that trip where it affects only the car and I can readily reset it to have another go at starting charging. With luck it might be slightly more sensitive than others so it goes first?
- Real Name: Joseph
I have a solution.
Possibly
This is what I did.
Possibly
This is what I did.
- Real Name: Joseph
Completely agree with you.
I’m not an electrician
But
But
- Real Name: Joseph
- Real Name: Joseph
- Real Name: Joseph
