The following article links to a gentleman by the name of Robert Catalan and a breakthrough which should have been made decades ago.
Some of you would know that the Electromagnetic flux produced in conventional electric motors is 50 % waste , because typically only one "end" of the magnetic force is being directed to produce kinetic effect through the airgap.
Mister Catalan and his Focused magnetics addresses this issue ( my guess is by using timed opposing electromagnetic windings ) similar to Halbach arrays , except they are not permanent magnets , they are presumably switched at the right times to redirect magnetic force as a cumulative directed influence.
What this means is any electric motor including Axial Flux and radial flux can all be increased in efficiency from ~ 50 % to much closer to 95 - 98 % efficiency.
This means you get double the range from the same battery , you also get double the power from the same motor = smaller lighter motors.
** Be excited **
https://becomingborealis.com/klaus-halb ... t-catalan/
https://www.youtube.com/watch?v=EQLBzoVHt6A
Huge breakthrough for EV's
Re: Huge breakthrough for EV's
Electric motors are *already* 90 - 95% efficient. To get above tends to require superconductors as most of the remaining losses are resistance losses rather than magnetic losses
This reads like an investment scam
2023 BYD Atto 3 - 21k km
2017 Renault zoe - 147'000km
2007 Vectrix - 50k km
- Real Name: David
100% efficiency in click and eyeballs though.
That's a variation on Chrysler's Turbo Encabulator which I think isn't the original one that was truly superb deadpan gobbldegoop.
They were both brilliant video clips....
- Real Name: Terry Covill
Loved the Chrysler dealership tech video at the end, priceless
- brendon_m
- Real Name: Brendon McCarrol
I feel that the tech advances of the hybrid encabulator as explained by professor Kelly are probably more on topic
https://youtube.com/watch?v=kgSXC-YhpUk ... IECMiOmarE
- Scotty T
- Real Name: Scott Taylor
Thanks @brendon_m, I've always wondered when the Encabulator would go hybrid!
