Looking for 2x calb 40a/h
Looking, to see if anyone has 2 x40amp hour calb lifepo4 cells they wish to sell .
- jonescg
- Real Name: Chris Jones
Re: Looking for 2x calb 40a/h
Hi Dan - might be able to help. I have a battery which belongs to someone else, but I don't think they will be using it again. Will find out.
Thank you. Will wait to hear
- jonescg
Hi Dan, I still haven't heard back from him. I hope he's not passed away, as he was not well. Either way, if I can't get a hold of him, I think they're probably due to go to a better home.
Dan do you need the older blue case size 40Ah cells? Or the newer 115mm wide grey case size cells? I have a few of the former
Wait, never mind, I just realised mine were 60Ah cells (with 35Ah or so remaining capacity)
- Real Name: Terry Covill
How many do you have? I'm interested as I need a few as well.
Chris, what is the physical size of these cells and how many do you have?
- jonescg
180 x 115 x 45.
16 of them with EV-Power cell top modules on them.
I still haven't heard from the owner of them, but will try once more.
- jonescg
Hi @Dan007a and @T1 Terry
Still haven't heard back from Brett Gilles, but there are three folks with pressing needs for these cells.
These are the grey CALB 40 Ah cells measuring 180 x 115 x 45 and have 16 of them. Ian Porter needs as many as he can get for his Vectrix, so if those who need only a few can get in first he;ll take the balance.
What price each? I'll take as many as you will part with if the price is good .....
- jonescg
OK so two for Dan, one for Simon, and the remaining 13 split between Terry and Ian? Ian needs probably about 7 for his Vectrix.
- jonescg
Ian needs about 18 of them, so sorry Terry, I might keep it local. At least this will get three EVs back on the road
These border issues are getting worse eh
No worries, maybe a few more tired EV packs will come up in the future that I can scavenge a few cells from ... or maybe even the whole pack if the price is right
- jonescg
Hey Terry, Ian has changed his mind, so if you want to buy 13 of them you are welcome. How's $500 sound?
I can send them with Northline, so that might be about $150 to SA. Comes with EV Power BMS cell top modules too if you're interested.
@Dan007a and @Simon I've set your cells aside, so let me know when you want to collect them.
You realise that's a photo of 12 cells, right?
- jonescg
Yes, the other four on the bench below. I had initially set 4 aside, but turns out I only need set three aside.
