The charge port is no longer at the front! It seems to be at either side now (DC fast charge port one side, AC charge port on the other side). At least it's near the front (just ahead of the door, near the top of the bonnet).
Edit: It looks like active cooling for the 85 kWh battery.
PiMan wrote: ↑Fri, 25 Oct 2019, 14:39
Maybe ... it will have less range than the original Leaf.
I believe that they're claiming 480 km (300 mi) WLTP.
T1 Terry wrote: ↑Fri, 25 Oct 2019, 09:18
85kWh battery, where will this end, a battery with more range than the person driving the vehicle or the comfort limit of the passengers?
It seems the marketers have cottoned into range anxiety and we have an arms race for the best range. Once everyone recognises they won’t need that range th battery size will probably come down, along with the total cost of the vehicle and the effociency will rise with lower weight.
The 85kWh battery would make an amazing off grid battery for when the vehicle was parked up ...... I'd love to be able to buy a Kona and work through making a plug and play set up to use that big battery pack in an off grid set up that supplemented a small permanent battery pack that kept the system alive while the EV wasn't plugged in.
T1 Terry wrote: ↑Sat, 26 Oct 2019, 10:58
That sort of setup could lead to ducking down to the shops to buy some sparks, not milk. It’s strange that we are obsessed with cars that use much more energy as a house full of people.
The are a few shopping centres in Adelaide that give you 1 hr free parking while you are EV charging as a method of attracting shoppers and getting them to shop that bit longer while their car recharges. So you could nip down to the shops for an hr and bring back some power for the house along with the shopping
T1 Terry wrote: ↑Mon, 28 Oct 2019, 14:59
I was considering (not very seriously) sticking a couple stumpy storage HWS units in the back of my car (ICE at this stage unfortunately - might need a some EV stickers and an exhaust pipe trim to complete the illusion), to bring home a couple days of hot water at a time, the house is all electric, and is pretty efficient for uncontrolled load due to a grid connect system and a off grid system to run the essentials at night (about 2-3kWh import a day on average for the year) but the wife loves a hot bath, so goes through 8-10 kWh of hot water a day... storage hot water tanks are much cheaper than batteries for getting that energy home.
