tractor conversion
pirpy
Real Name: Borut Lesjak
tractor conversion
Post by pirpy »
Hello
I want to convert small tractor to EV
I have 16 x lifepo4 200 Ah for the project.
I want the conversion to be as cheap as possible, so Im looking to rewind industrial 4 pole 400 V AC motor 7.5 kWh to 22V .
original diesel engine in this tractor is 31 kW peak at 2250 rpm and 149 nM torque at 1400 rpm.
what peak torque can I expect from this motor?
As I understand I need to add an encoder to the motor, where can i get one that would work with let's say Kelly KAC-8080I
or would 10kW bldc be a better option ?
Thank you
Renault ZOE R240 upgraded to 41kWh
scooter govecs GO1.2 converted to lithium
Solar installation 11 kWp
20 cow's
Re: tractor conversion
What kind of work will it be doing? Will it be doing any serious cultivation or mainly towing things? Because the motor need not be too amazing. A re-wound industrial AC motor would certainly fit the cheap requirements, but it might need some kind of cooling added.
4 pole is ideal for most applications, and any VFD will make it spin, you just need to find a reasonably efficient one.
An encoder is only needed it you want fine torque control. On a tractor you could probably get away with either speed control only, or course torque control that running open loop without an encoder would offer
pirpy wrote:
Thu, 24 Oct 2019, 05:58
...rewind industrial 4 pole 400 V AC motor 7.5 kWh to 22V .
Although the specifications match your tractor I'm skeptical that someone would rewind it to 22Vac.
When you think about 400Vac/22Vac this is 18:1.
I'd think this would mean you'd only have 3 or 4 conductors per slot.
Or many in parallel.
This would add perhaps AUD$1,000 to the cost of the conversion.
Possible alternatives are a series DC motor:
A00-4009
203-06-4001
ME1002
Possible alternatives for Magnet motor:
ME1302
ME1616
ME1507
pirpy
Post by pirpy »
antiscab wrote:
Thu, 24 Oct 2019, 08:51
thank you !
It will be doing light work, for heavy work I have this one
[tube]https://youtu.be/e2CAHfJqlFM[/tube]
The speed controll would be the best for tractor as it is the case with diesel engine.
The rewinding will not be the problem I would use the same wire but meny of them in paralel, the problem I'm expecting is with 3 or 4 wounds per coil I will not be able to make the motor 22 V but hope close to that .
I could lift the battery voltage but I'm planning to simply put my power wall 48 V lifepo4 cells to tractor and then use it for both aplications :)
Local rewind shop would charge me 300 € for rewinding 7.5 kW motor to lower woltage , and I already have a suitable motor in my junk bin :
7.5kW 4 pole 400 V
7.5kW 4 pole 400 V
I also have a DC motor in my junk bin:
72 V 80 A series DC  motor
6 kW DC.jpg (662.12 KiB) Viewed 635 times
I gues I could rewind the stator coils to lower voltage but this one does not have shaft that would allow me to mount a flywheel, ....
Comments appreciated
20 cow's
The Kelly controllers do seem to be the cheapest option for an Induction motor.
KAC72601-8080I USD$700
KAC72701-8080I USD$800
They require a "Dual channel A/B encoder" to work.
I'm assuming they mean a quadrature encoder.
Please don't buy this it's only an example
https://www.aliexpress.com/item/893080068.html
A curtis controller might work too:
1234SE-452X
1234SE-562X
But I expect they'll be harder to get and cost more.
pirpy
Post by pirpy »
So kelly or slider will not work without encoder ?
in speed mode?
slider:
https://www.alibaba.com/product-detail/ ... 3e5fw0fNC3
20 cow's
likely the best answer is we won't know until someone tries it.
There may be a setting to run straight v/hz
It would be worth contacting kelly controls and asking
I did scan over the kelly manual yesterday and I was under the assumption it is required.
Someone must have already done it - its a case of finding it.
When I have more time...
